Case Mod - In Progress HeretEK-An EK Vulture build
Discussion in 'Project Logs' started by B NEGATIVE, 16 Feb 2015.
  1. Vognen
    Vognen Minimodder
    2 Oct 2013
    Quoted for truth! The case is, in my opinion a little bit too big to house "just" an ITX board :lol:
  2. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    OOh, I would buy this...
  3. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    Once its done,you may get your chance.
  4. B NEGATIVE
    8 Aug 2011
    For me,this case is a little short on cooling 2 GPU's and a CPU,an extra 120 would of been nice but there is literally nowhere for it to be mounted.
  5. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Only way I could see would be to mount the tube res off the 360 and stuff a 120 above the PSU, but that would be hard to pull off without being ugly.
    Nice clean loop! :thumb:
  6. B NEGATIVE
    8 Aug 2011
    Agreed,for the intended purpose,its perfectly fine in stock trim
    Got to keep it clean Nexxo,the secret of any good build.
    True,but the space can be utilized,its gives a modder a better chance to do something different.
    Then you have a rad recycling warmed air,you wouldnt gain anything.
  7. B NEGATIVE
    8 Aug 2011
    And an hour on the bench polisher later.....
    CPU block has been rotated for the correct flow path and the tube has had all the cutting back and tweaking done. I wont need to do any more polishing because of the candy coat,if this was a full bore polish job then I would still be at it till the small hours.....
  8. Noob?
    Noob? What's a Dremel?
    18 Oct 2009
    Will it be swinging its way to me after you're done with it? I'll treasure it. :D
    Awesome work as always, looks astonishing mate.
  9. Spaceraver
    19 Jan 2006
    If I hadn't just plopped down 2K on my current build less than a month ago, I definitely would buy it. I just spent the better part of the night running copper tubing throughout my case. I ran out of tubing though. Need about 40 cm more to complete the loops. And solder the lot of it as I'm using fittings.
  10. B NEGATIVE
    8 Aug 2011
    Well,the candy coating of the tube went to pot,it looked so bad....the thinners rag was got out immediately and it was removed.....
    You know that cheap chrome plated plastic for kids toys? Yeah..just like that. So..polished copper it is.
    Sleeving this weekend and I cant wait to take finished pics of it.!
    In the meantime...
  11. Icelander
    Icelander Minimodder
    3 Mar 2015
    Looking rather :jawdrop:
  12. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    Looks lush. I remember enameling metal in CDT as a kid at school, is that possible for pipes?
  13. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    :jawdrop:
    From the last pic it seems the paint has a rough finish ...is it?
  14. B NEGATIVE
    8 Aug 2011
    Its the texture from the panel showing in the clear,its needs a polish back
  15. Cheapskate
    13 May 2007
    Dang. Paint too gaudy then? Still, the plumbing looks sharp.:thumb:
  16. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Looks very wine-ish, which appeals to this old alcoholic. :D
  17. B NEGATIVE
    8 Aug 2011
    And done...just in time for the deadline. All wired and working,need to black vinyl the HDD tho and generally tidy up and dust out....
    Final pics tomorrow!
    In the meantime...have some fresh from the bench shots!
  18. Falqoon
    Falqoon Minimodder
    13 May 2013
    I love it, very nice man, can't wait for the finals.
  19. Primum Agmen
    Primum Agmen What's a Dremel?
    21 Sep 2012
    I can't be the only one who is gutted they didn't use their own logo as the power button, right?
    Really loving what you've done with this - a B Negative build just isn't complete without some clean copper loving. :rock:
    Now, how do we convince them to make a few tweaks to the case and release it commercially?
  20. B NEGATIVE
    8 Aug 2011
    So.....final pics?
    Many thanks to EK for giving me this chassis to work with,Crucial UK for providing the DDR4 kit and BeQuiet for the PSU.
    Now for some fine weather for outdoor pics!
