Case Mod - In Progress [HEXGEAR] | IDORU |
Discussion in 'Project Logs' started by B NEGATIVE, 20 Dec 2014.
  1. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    ...............$400.
    Half the price of the machine....ish.
  2. B NEGATIVE
    8 Aug 2011
    Some shots with the plates in place and the res is tapped and fitted in preparation for the loop start. I still need to trim the exterior of the gasket down but its completely watertight....but now it has the taste for Human flesh after the chunk it took out of my finger....
    I cut 24 mm spacers for the SSD plate, to clear the Bitspower 90's connecting the pumps, and screwed directly in to the chassis for a great fit.
    I dont like the background tho...this a was a black one I mistakenly washed in the machine.....with detergent......
    Silly Neg.
    I will get the grey background out again.......XD
  3. storm-83
    storm-83 Member
    7 Nov 2014
    Can't wait to see that res filled!!!
  4. Icelander
    Icelander Member
    3 Mar 2015
    oh man. This is Totally looking Mod of the Year imo
  5. Cheapskate
    13 May 2007
    It will be interesting to see how many moty rigs have been touched by the pope this year. :lol:
  6. B NEGATIVE
    8 Aug 2011
    It definitely weighs in when it filled....and its slippery as [INSERT EXPLETIVE HERE]
    Lets wait till its finished? :)
    Lets see how many modded ones pop up.
  7. Noob?
    Noob? New Member
    18 Oct 2009
    Oh man, I just had to pick myself off the floor man! :jawdrop:
  8. bionicgeekgrrl
    bionicgeekgrrl Member
    1 Oct 2009
    Looking great :)
  9. B NEGATIVE
    8 Aug 2011
    IDORU makes more headway!
    Slowly anyway.....
    The accent parts are polished and are nearly all fitted.
    Not much more to do other than sleeve and finish the loop. Tubing will be a mix of Copper and Glass tube
    Just waiting on a second windowed door for the HDD side and she will be ready for EGX!
  10. Cheapskate
    13 May 2007
    TOO polished!:lol: For a second, I was looking for the GPU.
  11. B NEGATIVE
    8 Aug 2011
    Lol!
    Nate said the same......
  12. B NEGATIVE
    8 Aug 2011
    Productive morning for me,Second GPU fitted,wiring done and all I need to do now is the glass and copper loop.
    Then its the tiresome job of a final polish with Autosol........
  13. hairyknacker
    hairyknacker Member
    25 Jan 2012
    mmmmmm, Blue cables :thumb::rock:
    Just need a liddle-a something on the SLI bridge
  14. Cheapskate
    13 May 2007
    No wax? It seems like the inside will tarnish before you finish touching up the outside. Then you have the outside tarnish again and a vicious circle begins.:worried:
    I can see the GPUs now. I followed the cables.:lol:
    Also: Glass? Real glass? :D I can't remember if you are the one that did that before... If you keep up this fancy one-upping your next rig will require platinum and crushed diamonds.
  15. B NEGATIVE
    8 Aug 2011
    I have only a week before this one is display at EGX,the acid etching and clearcoating will be done after the event as I can pretty much guarantee that it wouldnt be finished in time otherwise.
    The tube is 12/9 borosillicate glass,I have tried this before but with bends and thinner tube,it didnt go well as I couldnt stress relive the tube after forming it....it all broke when I installed it in the case.
    Hopefully this thicker tube will resolve that.
    I think that as a 'recognized' modder I should push whats possible,something's work,some dont but its fun either way. I enjoy working with new materials,stretches the ol' skillset.
    Also.....
    :D
  16. Cheapskate
    13 May 2007
    Yep! doing it different every time increases skills, fun, and most importantly, toys.:lol:
    -Are you sure you want to give Magoo access to something like that? He could build a death ray.
    "I have marked the divan. Pray I do not mark it further."
  17. B NEGATIVE
    8 Aug 2011
    :lol:
    I totally laughed at this.
  18. B NEGATIVE
    8 Aug 2011
    Basic loop layout is done,glass tube runs to be cut after EGX....although there is such a small amount of straight runs that I may just use the glass on another build,it would look like it was thrown in for the sake of it.
  19. Impeccable Logic
    Impeccable Logic Member
    9 Mar 2015
    Awesome job :rock:
  20. B NEGATIVE
    8 Aug 2011
    In other news,the loop is in and polished. Ready for a leaktest!
    I changed it from the original design as the tube blocked the pumps....
