Modding Hey guys Check This Out!!!
Discussion in 'Modding' started by AnionWeed, 23 Jun 2004.
  1. AnionWeed
    AnionWeed What's a Dremel?
    21 Jun 2004
  2. mrplow
    mrplow obey the fist!!
    5 Sep 2001
    A premod! Awesome
    "Ok so this is the only modding i've done, cut out the crappy fan grill that was the case's, sanded out the rough edges and as you can see, my dremel works!!!"
    :rolleyes:
    Gosh what a mean reply. I apologise. Looks like a nice case, but there's not really much (any) modding done to it. I hope you will look around the forums and get inspired to make the case your own with some mods :)
    Are the front bolty things LED lit by default?
  3. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    You're so cruel :hehe:
    But I agree, the "second mod" isn't much of a mod at all. The first one is pretty cool though, you actually did some serious modding to it.
    I may need this to comunicate.
  4. AnionWeed
    21 Jun 2004
    Yeah it is kinda of a pre-mod, but who said i'm done messing w/ it?... :D i'm probably gonna paint it another color, cut out hole so that i can put a fan to cool down the back of the mobo, maybe put a window on the other side too and replace the mobo tray w/ acrylic plastic. I think that would look cool, but right now i'm working on the other mod. i'm giving it a gangsta look. Black w/ shiny bolts holding the clear acrylic plastic that is the window. and much more, i will be posting pics of it later. So for now u guys just keep on :rock:
  5. mrplow
    5 Sep 2001
    Good good. :dremel:
  6. ubernewber
    ubernewber What's a Dremel?
    23 Jan 2004
    that shizznat sure be tight.....yo
