HFM.NET - Client Monitoring Application for Folding@Home
Discussion in 'bit-tech Folding Team' started by harlam357, 17 Jan 2010.
  1. standinwave
    standinwave Folding in memory of my mum
    7 Jun 2009
    I tried this to no avail:
    Uploaded with ImageShack.us
    Filezilla works but this gives error 550, test connection failed :sigh:
  2. standinwave
    7 Jun 2009
    Still doesn't work, but now a different error :wallbash:Maybe it is blueyonder?
  3. StreetSam
    StreetSam Minimodder
    30 Aug 2005
    Sorry I forgot, Fling is the prog I use to auto upload the webpage.
  4. standinwave
    7 Jun 2009
    i shall try that! Thanks
  5. standinwave
    7 Jun 2009
    Fling worked! :clap: Thanks for that one!
  6. houch
    houch Minimodder
    26 Mar 2009
    hiya, is there instructions on how to set this up anywhere as i have no idea what im doing thank u
  7. houch
    houch Minimodder
    26 Mar 2009
    dw sorted it
  8. CraigWatson
    CraigWatson Level Chuck Norris
    9 Apr 2009
    Shame that this doesn't run on Linux, seems FaHmon is the only way to monitor Linux clients :(
  9. StreetSam
    30 Aug 2005
    HFM 0.9.0
    Hi All,
    Anyone tried this with the V7 client yet?
    I thought I'd try the V7 client on one machine to see what it was about. Then realised that I couldn't monitor it. Then I found the new version of HFM that does. Only to find that I can't get it to work. :eek:
    I have both machines firewalls turned OFF.
    I have a remote access password set and the ip of the monitoring machine added to the remote access allow list in the V7 client.
    I have the password and ip address of the v7 machine configured in HFM, but no luck.
    What have I missed?
    ***EDIT***
    Doh! I needed to restart the FAH client, all fixed.
  10. FingAZ
    FingAZ What's a Dremel?
    4 Feb 2012
    I'm running the FAH7 client on Debian 64bit too- but can't get it to monitor in HFM no matter what- could you post an example of your config perhaps?
    I'm running with "--command-allow 192.168.0.6" and i still get
    Code:
    13:43:15:Server connection id=1 on 0.0.0.0:444 from 192.168.0.6
    13:43:17:WARNING:Command server access denied
    What i'd really like is to allow all, as i'm using a passphrase anyway- but putting in "0.0.0.0" or "0.0.0.0/0" don't work either... could it be because i've changed the command port?
    Edit: Also worth mentioning is that in order to get it to listen on this port i've had to switch the running user to root... Not massively secure, but meh!
  11. StreetSam
    30 Aug 2005
    Sorry can't help all mine run some kind of Windows.
  12. FingAZ
    4 Feb 2012
    No problem, have posted a new thread instead in case someone can help :)
  13. Scorpuk
    Scorpuk Minimodder
    10 Jan 2012
    New update available and this will work with linux 12.04 and create web stats. Version 0.9.1 - Revision 595 :clap:
    Got it up and running on my server (Linux 12.04) and sending stats to my ISP's web space via ftp :thumb:
  14. DocJonz
    DocJonz Another CPC refugee .....
    24 Apr 2009
    New version of HFM.net released today - this one also supports the v7.4.4 Folding interface.
  15. Scorpuk
    Scorpuk Minimodder
    10 Jan 2012
    Cheers Doc. :thumb:
    Maybe time for an update.
  16. desertbaker
    desertbaker Steady Eddie
    21 Sep 2013
    Changing 'name' V7 help!
    OK, got version 0.9.2 revision 712 installed with F@H 7.4.4 on Win 7 64 bit. I have 4 slots on this machine, 2xGPU and 2xCPU. Through searching various sites found out if you use CLIENTS, then ADD CLIENT you can do as it says on the tin by using the client address of 127.0.0.1. This though gives me the name I gave it followed by the slot number, so in my case "Desktop Study Slot 00" as a name and then "Slot 01" next line, Slot 02" next line and lastly "Slot 04" on the last line.
    I have spent what seems days searching, reading forums etc trying to give these a more intuitive name like I see most of you guys have achieved. I give up, please, please put me out of my misery! :wallbash:
  17. DocJonz
    24 Apr 2009
    I'm not sure that most of us have done anything fancy - I certainly haven't!
    Who's HFM stats are you referring to where they have renamed individual slots within a single v7 client?
  18. desertbaker
    21 Sep 2013
    DocJonz
    Thanks for the reply. I have had a closer look at yours and several other summary.html's and it looks as though you have just been a little more creative in your naming than me. The screen shot on page one of this thread gives the impression each slot is named differently but of course that was an older version. I assume it is therefore not possible to rename individual slots within a single v7 client.
  19. DocJonz
    24 Apr 2009
  20. Scorpuk
    Scorpuk Minimodder
    10 Jan 2012
    bleh wrong thread. :(
