Other Hi from Forgedawg!
Discussion in 'General' started by FORGEDAWG, 15 May 2026.
  1. FORGEDAWG
    FORGEDAWG What's a Dremel?
    15 May 2026
    Been lurking around the bit-tech forums for a while now and finally decided to sign up and get involved. I've spent way too many hours scrolling through the Project Logs here, the builds you guys put together are pretty impressive!
    I’m currently in the early stages of planning out a custom wall-mounted setup. I'm trying to move away from a standard case and do something a bit more open and vertical. I'm mostly focusing on the 'how-to' side of things right now, like cable management and making sure everything is structurally solid.
    Looking forward to picking your brains once I get my head around the planning phase. See you around the boards!
    Cheers,
    Forgedawg
    Pete J, b1g-d0g, Kehoe and 5 others like this.
  2. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    Welcome o/
  3. FORGEDAWG
    15 May 2026
    Thanks for the welcome! It seems like a great community. Quick question for you, I'm planning a vertical build that uses a wooden backboard instead of a standard case. I have some technical questions about mounting and grounding on wood.
    Should I head over to the Modding sub-forum for that, or is there a better spot for custom 'scratch build' questions?
  4. Kehoe
    Kehoe Minimodder
    9 Aug 2015
    Welcome to the forum.
    Yes the modding section would be a great place to start a thread. But from my understanding, wood isn't conductive so you wouldn't need to ground it, most modern hardware would be fine as the PSU is the main ground for things. The only concern would be dust and static but electroboom on YouTube covered how much static it takes to kill a modern pc soo you'd be fine.
    I've had a exposed motherboard screwed to a board in my garage that I used a printer server for years 0 issues, that poor thing got abused
    pete*, boiled_elephant and FORGEDAWG like this.
  5. FORGEDAWG
    15 May 2026
    Thanks ill post in that section giving a more detailed spec and see what folks come up with.
  6. The_Crapman
    5 Dec 2011
    Welcome! Always nice to see a new member. There's been a fair few epic wall mounted builds. You could try looking through prior mod of the month nominees to find some inspiration.
  7. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    Welcome!
    Modern PCBs are coated in something, I think, aren't they? Very well protected from atmosphere. I've left components in dubious conditions and been surprised how no corrosion forms. It used to be common to see rust on motherboards at one point.
  8. b1g-d0g
    b1g-d0g Multimodder
    30 Sep 2001
    Wellcome to the mad hoose, great bunch of guys and gals on here :rock:
