Hi, welcome to project grille :D pc-60 stylie
Discussion in 'Project Logs' started by bleecher, 25 Apr 2004.
  1. bleecher
    bleecher New Member
    25 Apr 2004
    ive been talking about it for a while now every1 has feel in love with this mesh ****e, id like to point out iv e been doin pc mods with mesh for a few years now -but this is the first major one :D
    Right This is the case iev bought and started modding a lovely pc-60>
    and this is my concept art (yeah i know):
    this is the puppy in bits :) as you can see i spend no money on carpets :D just pc stuff
    STEP ONE:
    This is the first step, the dremeling
    i cut the grill out of the rear exhaust, to enable better air-flow, and as soon as ican find a 80mm hole saw il do one below.
    it was very easy to cut, due to it being aluminium, id hate to do dremeling on a stell chassis.
    And this is the fooker that came out of it
    STEP 2:
    ive also now marked up the cut out for the front bezel, tis faint but its there.
    i put some drapes up for because some1 asked for some drapes in the photos :S so i took the piss :D
    STEP3:
    this one was after 4hours of dremeling, as you can see on the right is the insert and drive bays i removed. - i didnt take a raw shot as i forgot so i dont a quick comparisson.
    54 discs that baby ******ed - and the dremel packed up so i cant do much more
    and this is a quick shot with the mesh behind -all thats left is for me to attach the grill and cut out 2 drive bays and the USB hole at the bottom. i will be attaching the grill with clear silicon and the bays will be stealthed using the origional bezels.
    i will be starting again soon, so some more piccys will be up shorty :)
  2. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
    Looks pretty good but if i was you id loose the moulding and get a file out ;)
  3. n0ll4k
    n0ll4k New Member
    1 Jun 2003
    nice mod
    i second the thing with the molding
  4. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    G5... can you say G5... interesting. Li Lian is coming with a stock case with this look soon...
  5. Mixx
    Mixx New Member
    19 Oct 2003
    looks good....
    but i agree... moulding looks horrible
  6. bleecher
    bleecher New Member
    25 Apr 2004
    filing u say, my edges a rough and wonky as **** without the trim :D
    any recommendation on how to smooth it out?
  7. Darv
    Darv Bling!!
    12 Aug 2002
    Files, time and a lot of elbow grease. Its the best way really and it would look very good :cooldude:
  8. planki
    planki ...
    20 Dec 2003
    54 discs!!! 54discs!! jeeez thats a lot!!
    looking good by the way!
  9. Mondak
    Mondak New Member
    27 Dec 2003
    Yep - lots of elbow grease instead of the trim will make this thing. It looks like you are headed the right way though. I think it will be a neat case. The only question I have is how much dust will be inside after running it for a while. That mesh won't stop much.
  10. ubernewber
    ubernewber New Member
    23 Jan 2004
    i had those sheets when i was like in kindergartern, turtle power!!
  11. technomancer
    technomancer New Member
    2 Apr 2004
    My first thought as soon as I saw the thing.
    I do like the concept... though I agree on filing the edges. I'd also get a smaller size mesh.
  12. bleecher
    bleecher New Member
    25 Apr 2004
    nah i like the phat holes
  13. bee2643
    bee2643 New Member
    7 Mar 2002
    looks cool
    id loose the bedding though lol
  14. exavier412
    exavier412 New Member
    15 Jan 2004
    where do you get that mesh?
  15. bleecher
    bleecher New Member
    25 Apr 2004
    bought it from a garage, i know a place that does sell it but tis pricey as hell.
  16. Hephaistus
    Hephaistus New Member
    11 Mar 2004
    Looks good, but I would never do that to a lian-li case. because the front of that's case looks so nice on it's own.
    I will start a project sone also with a lian-li case but I'm NOT touching that front, it's way too stylish (and expensive)
