Cooling hidden leak
Discussion in 'Hardware' started by KayinBlack, 11 May 2005.
  1. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Sorry for poor formatting ahead of time.
    Posting from the backup, somehow my system has a small leak, and I can't for the love of sweet baby Jesus pinpoint where it is. There aren't any puddles, but it lost all the reserve water inthe T line and then started sucking air hardcore. Woke me up this morning it was so noisy. Anybody got any tricks to pinpoint leaks? My dye isn't UV reactive,so that's out...
  2. silentphoenix
    silentphoenix What's a Dremel?
    1 Sep 2004
    What i did once was put toilet tissue arround each of the joints and after a lil while check for any dampness. This would work much better if you have some coloured tissue.
    Not sure if this helps as I dont really know how small your leak problem is tho..
  3. Nexxo
    23 Oct 2001
    Chuck some dye in the res. Use toilet tissue as advised. Else use a good torch and check every joint visually --also the pump housing.
  4. Holst
    Holst What's a Dremel?
    17 Nov 2001
    The toliet paper with die is the easyest way
  5. Firehed
    15 Feb 2004
    maybe blow into the T-line and see if you note any water or air escaping.
  6. KayinBlack
    2 Jul 2004
    Had a pair, did the paper towel thing.
    Had one from the video card block and one off the side of the pump. Got them both fixed and bled out now. Boy it's a lot quieter...
