A/V hifi unit speakers on pc
Discussion in 'Hardware' started by andrew, 25 Sep 2003.
  1. andrew
    andrew What's a Dremel?
    11 Aug 2003
    Hi everyone, well I just inherited this hifi unit totally for free. *bonus*
    Tried them out and they are loud with loads of bass. Well, I have no use really for this as I'm building a media pc. But can I connect these speakers to my via epia 800 mini itx mobo? They are just 2 bare wires (can't describe exactly) 1 black, 1 black/white. With bare ends that are pushed into the back of the unit.
    Can I use these some how?
  2. penski
    penski BodMod
    29 Aug 2002
    You need an amplifier before the signal gets to the speakers.
    *n
  3. andrew
    11 Aug 2003
    would that involve like another huge box of tricks of could I get a tiny one somewhere?
  4. dfhaii
    dfhaii internets
    24 Mar 2002
    you have just been given one ;), on the 1ft box down (under the turntable in the pic) on the back of that there might be 2 phono connectors for line in, if you attach the epia to this (with a 3.5mm stereojack to 2 phopno cable) then u will use the auxillary on that amp to drive them.
    Col
  5. andrew
    11 Aug 2003
    well I'll rip it open and see.
    The 2 wires on each speaker go into these little holes, which are locked in with little clips. There is also 2 things for red and white plugs. (audio)
  6. dfhaii
    dfhaii internets
    24 Mar 2002
    yea thats the ones does it say line in anywhere near them, if so u just need the cablke and your all set :)
    Col
  7. andrew
    11 Aug 2003
    ok I've ripped out the amp. Such a messy process. Um. I don't know how and if it could work.
    11 wires went to the psu.
    8 wires went to the input thing or volume
    3 wires in a sleve went to the radio board.
    Anyone got any idea if I can get this to work :confused:
    I think I just wrecked a working hifi unit. Carp.
    picture in a minute.
  8. andrew
    11 Aug 2003
    theres the pic.
  9. dfhaii
    dfhaii internets
    24 Mar 2002
    :O y u take it out of the box lol
  10. andrew
    11 Aug 2003
    It seemed like a good idea at the time.
  11. micb
    micb Minimodder
    4 Sep 2002
    I do not think pulling the amplifier stage out was such a good idea.
    It would have worked fine before you hacked it apart, all you needed was a low level signal simple cable from motherboard to the back of the unit and all would have been great, but now you are going to have serious problems.
    It was an integrated unit so this means the "pre amp stage" with volume controll, "amplifier stage" and power supply were integrated together, you can't use one without the others so you are pritty much stuck.
    Next time it may be wise to ask a few people who know about HIFI equipment before ruining your hardware.
  12. Stew
    Stew Disgruntled Postal Worker
    6 Mar 2002
    Mongo Smash! :brrr:
  13. samuelellis
    samuelellis What's a Dremel?
    19 Apr 2002
    with some luck you may be able to put the amp bit back in if you havent done any damage to the bits inside or the wiring
  14. andrew
    11 Aug 2003
    well, I think I ruined the unit. Oh well. :clap: :clap: my spazness
    At least I have a case for my media pc now.
  15. fathazza
    fathazza Freed on Probation
    20 May 2002
    lol,
    micb dont be mean,
    ripping things apart is fun. + it didnt look like the most valuable hifi in the world so not to much harm done
  16. Sord_Fish
    Sord_Fish What's a Dremel?
    30 Jan 2003
    well if you get another stereo with a turntable on the top and it doesnt have line in you can use the turntable input if you get what i mean.
    but you cant use the turntable but makes a handy line in
  17. dfhaii
    dfhaii internets
    24 Mar 2002
    not quite so, the turntable uses a phono connector, this is very very low level and so it will probably have a preamp stage inside the amp, there will probably be another connector by the phono in for a ground wire from the turntable to prevent ground loops (that humm)
    Col
  18. andrew
    11 Aug 2003
    it's dead ok, the bin men have taken, and it's not coming back.
  19. Mhiran
    Mhiran What's a Dremel?
    8 Dec 2002
    Hmmm...
    Have the bin men taken the speakers as well?
    I'm thinking that you could hook them up to a £49 Maplin amp, as you ruined that other one, get the line input from your sound card, use an aux cable from the card to the amp. Wire the amp to the speakers, routing it through a 1 way crossover, (I assume you just want the bass) and hook that upto the woofer input of the speaker.
  20. andrew
    11 Aug 2003
    I still have the speakers, but I don't have anything planned for them at the moment, as I am saving/selling stuff to raise money for a moped, I have like 29 days till my birthday, so I'm not spending a single penny untill then.
    Although I just shelled out £35 for a provisional :miffed: It's expensive
