Modding High focus white LED's?
Discussion in 'Modding' started by Randomboy, 16 Oct 2003.
  1. Randomboy
    Randomboy What's a Dremel?
    11 Oct 2003
    I'm in need of some very highly focused LED's. The less off axis light transmission the better. I dont know quite a whole lot about LED's, but I think theres a "viewing angle" rating :p
    Basically the LED will be at the base of a 1" (3/4" ID, 1" OD) hollow acrylic rod, with a piece of 3/4" rod as a stopper in the bottom (and top as well, as this will be for water transmission in a WC'ing setup :D :D), and I plan on putting at least one super bright LED at the bottom, shining up to illuminate the column of water. I just want to avoid being able to see the source of light when viewed directly from the side.
    Thanks!
  2. Dogg
    Dogg What's a Dremel?
    14 Sep 2003
    i dunno about any really fine beamed LEDs.. but maybe you could rig a type of lens on it to sharpen the beam?
  3. linear
    linear Minimodder
    5 Oct 2001
    15 to 20 degrees is a typical beam spread on a high brightness LED. 10 degree ones are available, but you're gonna pay a lot more. I'd try a stock one, I bet you'll be pretty happy.
    Of course, nothing beats a Luxeon Star/O:
    That's a piece of 1" acrylic rod end lit by a Luxeon Star/O. There is no substitute. :rock:
  4. Dogg
    14 Sep 2003
    yeah, the stars are awesome.. a lot of money tho :sigh:
  5. Astrum
    Astrum Dare to dream.
    8 Mar 2002
    I never knew you owned a lightsaber linear :p
    10 degrees is the smallest I've found... Actually its about 12.5 degrees. They are rather pricey though...
  6. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    Randomboy, as Linear says, just try a regular LED. The viewing angle is quite small anyway.
  7. Randomboy
    11 Oct 2003
    Ok, I didnt know one way or the other, but now I know :) I'll be doing that then. Hmmm, now just lotsa mcd :)
    And ouch....... it'd cost me 60 bucks to do luxeon stars under each rod :p Regular LED's it is! :clap:
  8. Randomboy
    11 Oct 2003
    Decided my case was gonna be smoked *gray tinted acrylic* with mostly blue accents everywhere........... :) Just ordered 35 4000mcd blues and 10 8000mcd whites from lsdiodes.com :) and the appropriate # of resistors as well :) I think I'll be making my own Luxeon stars, or cheap imitations anyways. I'm not gonna have everything lit up, but the things that WILL be lit up, are gonna be LIT UP :) mwahahahhahahhah
    mwahahhahahha
    mwhwhahhahahaha
    Cheers!
  9. Wolfe
    Wolfe What's a Dremel?
    7 Sep 2003
    you can file the plastic dome off the housing of most leds, you just have to be careful you dont hit the element. It is a pain in the a$$ tho.
    You have to polish them too, but you get a less diffused beam.
  10. Randomboy
    11 Oct 2003
    No wolfe, I WANT very focused beams, at least for my 16" long pices of 1" hollow acrylic that will have water flowing through them :)
    I replaced a few LED's in my brothers alarm keychain, went from this tiny little 1-2mm red LED to a nice 5mm blue one, I've dealt with filing them down before, I'll be fine.
    Went and picked up some PCB tonite, I'll have 3/4" circles worth of PCB to put under my rods, thinking I'll be able to fit at least 4 LED's per piece of board :)
  11. OtakuHawk
    OtakuHawk What's a Dremel?
    30 Apr 2003
    Linear, what's teh linkage to them Luxeon Star LEDs????
    I think I just found my new lightsaber. :D
  12. Theo
    Theo What's a Dremel?
    12 Jun 2003
  13. Wolfe
    7 Sep 2003
    less difused = more focused
  14. Randomboy
    11 Oct 2003
    I r no speek teh engrish :p Thanks :) That may actually come in handy, seeing as with flat tops I'll be able to butt them directly against the base.
  15. apoogod
    apoogod trix arent just for kids
    19 Jun 2002
    What resistor did you use on that linear? Also is that a 5v line?
