High power green laser pointer fun *pics; 56k warning*
Discussion in 'General' started by ConKbot of Doom, 12 Oct 2005.
  1. seebul
    seebul Minimodder
    9 Aug 2005
    I dont think the limit in the UK can be 1mw? I have a stage laser light which is rated at 45mw and its certainly not illegal for me to have it.
  2. Herbicide
    Herbicide Lurktacular
    27 May 2004
    IIRC there's a classification (thus power limit) difference between laser modules - what you have - and laser pointers.
    - H.
  3. Nexxo
    23 Oct 2001
    How visible the beam is depends on atmospheric conditions. If there is lots of dust or moisture in the air, it will be visible. If it is a very clear, dry night, you won't see a thing. And of course, it only works at night.
    I don't think a laser will have any practical application as a signalling device for backpackers. And remember, a green laser can cause eye damage from quite a distance, so it is not something to liberally wave about.
  4. Herbicide
    27 May 2004
    Greatland make/market lasers as distress flares, though these seem to project a line, rather than a spot to help guide in SAR teams.
    - H.
  5. pdf27
    pdf27 What's a Dremel?
    6 Jul 2006
    Other thing is that a laser is very bright when you're looking at it, but the scattered light due to dust is pretty dim. Remember that you're trying to produce a device to bring people's attention to the hiker, rather than necessarily to pinpoint them once the searchers know the general area. Chances are, unless it's pretty bright you'll miss it.
    You're probably better off with either some form of pyrotechnic (smoke grenade, Schermuly (parachute flare), miniflare, etc.). One alternative is what they use for jungle navigation - a helium baloon on the end of a long wire. You send it up, and they send out a helicopter to find it and tell you where you are.
  6. pendragon
    pendragon I pickle they
    14 May 2004
    wow... :sigh:
    Anyway.. cool laser, dom :) thanks for the pictures!
  7. Nexxo
    23 Oct 2001
    Are you commenting on something I said almost two years ago?
    Wow...
  8. Neogumbercules
    Neogumbercules What's a Dremel?
    14 Aug 2004
    Walk around with it on your head and go:
    "I am Locutos, of Borg."
    Just don't say it to anyone, just kinda do it to the wall or something, and have your camera set up to take a picture so you can show someone afterwards :thumb:
  9. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    So then gents, how do we go about building a handheld 1W laser pointer?
    Edit: TWO YEARS OLD? Oye, the photos still work, too...
  10. woof82
    woof82 What's a Dremel?
    18 Jul 2005
    I don't think semiconductor laser diodes can take that much power. You would need a gas laser. And seing as that would drain AA batteries faster than you can say "uh oh my face is melting" you would need a bigger power supply arrangement also.
  11. Tulatin
    16 Oct 2003
    Hrm. Well i did find a site offering 2000mW units...
  12. TheoGeo
    TheoGeo What are these goddamn animals?!
    10 Jun 2003
    convert this to work on battery power :p
  13. woof82
    18 Jul 2005
    Yeah they made a mistake on that description. It's actually 0.9mW.
    I saw an even worse mistake in a dodgy lighting equipment shop. It was selling a "50 megawatt laser module" obviously not realising the little 'm' actually meant 'milli.'
  14. TheoGeo
    10 Jun 2003
    ahh, i was a little suspicious of that description when i looked at the price. Couldn't be bothered double checking, it was too late.
  15. Nexxo
    23 Oct 2001
    Army surplus? After all, there was that Star Wars programme that never took off... :p
  16. pendragon
    14 May 2004
    Looks that way now, doesn't it? :thumb:
  17. Nexxo
    23 Oct 2001
  18. Amon
    Amon inch-perfect
    1 Jun 2007
    The beam scatter is almost guaranteed in most atmospheric conditions, depending where you live, due to our recent trend of metropolitan air quality. The dense carbon pollution of the locale will scatter the beam much more readily in broad daylight, depending on the locale.
    As for a laser's implementation as an emergency signaling device, it's not that bad of an idea. They are lightweight and their beam concentration is needed to reach passer-bys across, say, a mountain valley. Battery replacements can be plentiful and are very lightweight. You can see the necessity in carrying both a flashlight and a laser signaler as a laser won't illuminate a dark path while a flashlight won't reach a distant observer during peak hours of the day.
  19. Nexxo
    23 Oct 2001
    Most handheld lasers that are used as emergency signalling devices actually emit a slightly dispersed cone of light, rather than a focused beam. The idea is that you sweep the beam across the helicopter's/plane's line of vision so the pilot sees a bright flash emitting from the area where you are stranded when the beam shines (more or less) straight at him/her. The beam itself is not visible from any distance.
    Red lasers are preferable in that scenario, as they manage to last longer on a given battery charge. Green lasers are extremely hungry, and thus not much good.
  20. DreamTheEndless
    DreamTheEndless Gravity hates Bacon
    27 Jan 2004
    red lasers would also be better as red does not interfere with night vision.
    (And by night vision, I mean the biological kind - not the electronic kind.)
