Music High quality noise cancelling earphones
Discussion in 'General' started by Virus44, 5 May 2013.
  1. Virus44
    Virus44 What's a Dremel?
    2 Nov 2011
    Hi i was wondering if any of the great folk at bit-tech could recommend me the best noise cancelling earphones for their value i was looking in the price range of up to £100 any advice or help would be greatly appreciated many thanks :thumb:
    Virus44
  2. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    Do you mean noise cancelling like the bose ones, or just noise deading, without the active part?
  3. Virus44
    2 Nov 2011
    Yeah the type of noise cancelling that usually comes with Bose products
  4. fdbh96
    29 May 2011
    Its just that I was looking at similar products earlier this year, and found that you either got good headphones, and poor noise cancelling or poor sound quality and good noise cancelling, unless you spent a lot more. I'm sure there are people here who have found a pair, but I gave up and got a pair of B&W P3's which are pretty awesome :D
    Virus44 likes this.
  5. Virus44
    2 Nov 2011
    Fair enough just going to hope that someone here has found a decent pair of noise cancelling earphones if not i will try the audiophile forums surely they will know
  6. Tangster
    23 May 2009
    If you're dead set on active noise cancelling, Bose still make the best ones. They won't compare to standard headphones on sound quality, but they'll do well for a train journey or flight.
    If you don't mind IEMs, a pair of Shure SE215s or Westones with foam tips will isolate very well.
    Virus44 likes this.
  7. Mister_Tad
    27 Dec 2002
    Seconded the SE215s. With the foam tips, I reckon they isolate just as much noise as the Bose QuietComforts cancel.
    I've done a side by side test on a plane (personal SE215s, airline's QCs), and carried on using the SE215s for the rest of the flight.
    EDIT: I'm not sure if they were QC3 or QC15 though, I didn't realise they made more than one until just checking now.
    Virus44 likes this.
  8. TheCherub
    TheCherub Minimodder
    16 Sep 2007
    For the money I'd definitely recommend going for IEMs which will give a pretty good level of cut-off from the outside world and you can get decent sound quality for the money. I must confess I've never heard a set of Bose headphones that sounded all that good with anything other than very simple music, and I don't know of anyone else really doing the active noise cancelling thing.
    Virus44 likes this.
  9. Tangster
    23 May 2009
    Of course, if money is no object, a pair of Custom IEMs will offer the best comfort, sound quality and isolation. Prices range from £100 for a very basic single driver, to over £1500 for a top of the range pair, not including customs costs and fittings.
    Virus44 likes this.
  10. Virus44
    2 Nov 2011
    Decided to go for the shure se215 earphones thanks for the help everyone +rep for all
  11. IamJudd
    IamJudd Multimodder
    30 Oct 2011
    Just read that Kef have got into this area... Might have to have a look...
    Virus44 likes this.
