A/V High Quality Wireless Headphones, Several Users connecting to transmiter.
Discussion in 'Hardware' started by rainbowbridge, 26 Mar 2010.
  1. rainbowbridge
    rainbowbridge Minimodder
    26 Apr 2009
    The Sennheiser digital wireless headphones is an option but it only supports up to four receiving headsets (digital tx).
    Does any one know of some good quality headphones, even pro level if necessary, that can pick up from the a base station which is connected to the audio source (tv in this case), several headphones to be connected.
    thanks for your recommendation!
    :thumb:
  2. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    hmm you would that that wouldn't be a problem
    you might want to talk with turtle beach about their wireless base and mixing it with cheaper headphones.. know their x series is unlimited in the amount of headsets that can recieve from one base- mainly used for xbox though
    http://www.turtlebeach.com/products/efx31/featuressummary.aspx
