Displays High resolution 20" Monitor?
Discussion in 'Hardware' started by xrob, 22 Jul 2012.
  1. xrob
    xrob What's a Dremel?
    31 Dec 2005
    Does anyone make high resolution 20" monitors?
    Cant seem to find anything, I don't really want 24".
  2. Tangster
    23 May 2009
    What's "high resolution" to you? You won't find anything over 1920x1080 in the 20" market these days.
  3. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    What do you class as high resolution?
    I think you may have to look at 21.5" for 1920x1080 at least.
    It's not that much bigger and would give you a lot more choice.
  4. xrob
    31 Dec 2005
    Sorry, 1920x1200 would be nice, I prefer the 16:10.
    Currently have 1680x1050 Dell.
  5. samkiller42
    25 Apr 2006
    You wont find any 20" displays with that res. I don't know of any displays under 24" with that resolution.
    Sam
  6. KidMod-Southpaw
    28 Sep 2010
    I noticed you have an Nvidia graphics card. Some monitors will allow you to create a higher custom resolution using the Nvidia control panel.
  7. GregTheRotter
    GregTheRotter Minimodder
    9 Aug 2008
    I think NEC do some business grade monitors at smaller sizes and larger res. I went from a 20" NEC to a Dell u2711 and resolution increase is very nice. I think you're going to have a hard time finding something suitable.
  8. longweight
    7 May 2011
    Not higher than the screens native resolution though.
  9. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    There's plenty of 21.5", 1920 x 1080 screens on Scan but I doubt you'll get a 1920 x 1200 panel this side of a 24" Dell U2412M...
  10. KidMod-Southpaw
    28 Sep 2010
    Actually, when I had my old crappy 19" TN panel, that had a native resolution of 1440x 900 and I could scale it to 1920x 1080 just fine.
  11. Tangster
    23 May 2009
    Must be interpolated. You would be missing large amounts of detail, because the pixel density isn't high enough to display them.
  12. KidMod-Southpaw
    28 Sep 2010
    It looked ok actually when I was running it. Still, the move to this U23 was still massively awesome and 100X better! :D
    OP, I think you's be best going with this:
    http://www.scan.co.uk/products/23-l...l-hd-1920x1080-250cd-m-5m1-12-ms-dvi-vga-hdmi
    Cheaper than the 21" version too! :thumb:
  13. longweight
    7 May 2011
    It's still not a true higher resolution though.
  14. KidMod-Southpaw
    28 Sep 2010
    Oh I knew that, just increases the pixel density and hurts my eyes. XD
  15. tehBoris
    tehBoris What's a Dremel?
    30 Jan 2011
  16. xrob
    31 Dec 2005
    Thanks guys, guess no choice but to go for 21.5", really dont want anything too big.
    Cheers
  17. KidMod-Southpaw
    28 Sep 2010
    But the 23" version is £1 cheaper!
    Either way, get one of those 2 LG panels, you won't ever regret going IPS!
  18. hamza_tm
    hamza_tm Modder
    10 Apr 2012
    afraid you can't increase pixel density, it's a physical property of the screen and no software can change that
    N17 dizzi likes this.
  19. KidMod-Southpaw
    28 Sep 2010
    My terminology is awful. :(
  20. hamza_tm
    hamza_tm Modder
    10 Apr 2012
    We still love you!
