Motherboards High temps while playing skyrim
Discussion in 'Hardware' started by boltonuk007, 4 Feb 2012.
  1. N17 dizzi
    N17 dizzi Multimodder
    23 Mar 2011
    Not so much of a problem really, the CPUTIN/Motherboard sensor in windows is not working properly and I haven't got to the bottom of it. (others have reported the same)
    As I say, all it ever reads is 60c or 124c. In bios it's normal just in Windows does it do this. I've tried different monitoring software and they all say the same.
    I have no ASUS software installed aside from drivers.
    I do occasionally run at 5Ghz/1.45v for benchmarks and such but I am at 4.5Ghz/1.32v 99% of the time.
  2. boltonuk007
    boltonuk007 What's a Dremel?
    29 Sep 2011
    ah right, thought you meant problems other than the sensor issue. what temps do you get underload at 5ghz?
  3. N17 dizzi
    23 Mar 2011
    I haven't prime'd or burn tested @ 5Ghz since getting the dark rock with TY140 installed.
    With the tranquillo it was in the 80s (I do suffer with well documented high ambient which didn't help)
    Honestly I only clock that high for kamikaze bench runs, not interested one bit in running it day to day.
    4.5 is perfect for me, hottest core gets to 67c in prime, 29 - 34c at idle depending on ambient.
    Could be better perhaps but I'm happy with that :thumb:
  4. boltonuk007
    29 Sep 2011
    4.8 hangs around 30-32 idle. Intelburn gets it up to 75 which iam uncomfortable with. prime gets it up to 65/67 which is fine for me because skyrim only gets it up to 60. Although when I was first exploring the board i had the voltage set to auto when i first went for 4.8 and it put 1.6v through it! after I dived for the power button and wiped my arse I managed to get it down to 1.38v stable.
  5. N17 dizzi
    23 Mar 2011
    :lol: thanks for spraying tea over my K60!
    Yeah I had fun with auto and offset too...
    1.38 for 4.8 is good going :)
  6. boltonuk007
    29 Sep 2011
    haha, my next purchase!
  7. N17 dizzi
    23 Mar 2011
    You wont regret it, especially for Skyrim... such a nice feel and much more responsive
  8. boltonuk007
    29 Sep 2011
    to be honest Ive been using the wired xbox controller for Skyrim. Its designed to be used for it and changes the HUD and all the menus as if it was on the xbox if you know what I mean, its much better than using my bog standard microsoft keyboard/mouse
  9. ec928
    ec928 What's a Dremel?
    9 Oct 2011
    Skyrim puts some serious strain on my GPU, more so than most games. The CPU is fine, it's the GPU that contributes a lot of heat to my case.
    It's fine at first but eventually the case can't dump the heat out fast enough, so I let it rest a bit when VRAM temps exceed 110c (normally after a couple of hours). Saying that, I'm using a tiny mini-ITX case with one case fan, but with a full sized PSU and GPU, so heat build up is a bigger concern than people using normal sized cases. AIDA64 with the all the temps showing on the system notification bar (in W7) is a good way to track all temps.
  10. N17 dizzi
    23 Mar 2011
    Can you post a pic of your set up?
