Electronics High voltage!!
Discussion in 'Modding' started by H4wk1e, 19 Feb 2004.
  1. H4wk1e
    H4wk1e Minimodder
    7 Jan 2004
    HI, I have 6, turbo cool crystal fans with leds and two 12" neon lights in my case, and have a 550w PSU running it. Is this too much for the PSU to run of also along with all the other components? :worried:
  2. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    If it's a real 550w PSU than no. If it's a POS Qtec that a bunch of people on these boards got suckered into buying before realizing that they sucked/failed spectacularly, then probably not.
  3. H4wk1e
    H4wk1e Minimodder
    7 Jan 2004
    It's a Q-TEC PSU with duel fan.
  4. El_JimBob
    El_JimBob Minimodder
    28 Dec 2003
    The Q-Tec should be fine - keep an eye on voltages fluctuating tho - mine do a little.
    The Q-Tecs really arent as bad as everyone says they are - but with the price of better specced PSUs coming down u should go out and get a new one, which is exactly what ima gonna do soon.
  5. H4wk1e
    H4wk1e Minimodder
    7 Jan 2004
    ok! thanks
  6. Munterofamodder
    Munterofamodder What's a Dremel?
    1 Dec 2003
    id agree the q-tec psu aren't bad, they are just very misleading with their figures. the 550w q-tec can give out less current than for example a Antec Truepower 430W. Basically, if the q-tec were to give out 550w it would probably fail; think of it more as a 400w psu!
    That said, you will probably be okay - im guessing the lights and fans will use at most about 50W (4A on the 12V rail); this is a high estimate as well. If you only have 1\2 opticals, 1 hdd and not a top-range video card you will probably be okay. If you have lots of hdd\optical drives and a hi-spec system I would consider selling your PSU and buying a 'better' branded one just to be sure.
    edit: just seen your specs in the sig, and I would imagine you would be ok for now, but if you plan on upgrading you GFX or getting more hdd etc. the psu may become an issue!
  7. El_JimBob
    28 Dec 2003
    My QTec used to happily power all sorts of bells and whistles in my case. Never had any serious probs with it. Just got a new 480w Tagan tho, and u CAN see the difference a good PSU makes.
    At only £65 its a steal - stick one on the shopping list for next time u wanna upgrade, but ull be fine with the QTec for the moment.
