Highest CPU Temperature seen
Discussion in 'Hardware' started by Eliminos, 13 Oct 2005.
  1. Eliminos
    Eliminos What's a Dremel?
    2 May 2005
    So I was installing a barton 3200 in my sisters computer and I applied the thermal paste to the processor and to the heatsink (where i wiped the original paste off). What I accidently did was clip the heatsink on 'backwards' so the paste on the heatsink wasn't touching the paste on the processor.
    So I booted it up, checked the speed and then went to download MBM. At which point it rebooted. 'Oh shi-,' I thought as I checked the temperature in the BIOS.
    118°C
    I win.
    Until someone else posts a higher one.
    In my defence the heatsink is so much easier to clip on the way I clipped it on originally, the 'correct' way means forcing a screwdriver between the small gap between the heatsink and the PSU.
  2. hitman012
    hitman012 Minimodder
    6 May 2005
    That's hotter than my old XP1800+ under load by a mile, and I even reused the thermal paste on that ;). I'm amazed that you even got into Windows...
    Must have been quite an "oh shi...." moment, though.
  3. Firehed
    15 Feb 2004
    I've seen 127c, but I know for a fact it was a software glitch. Using the same software, I'd seen my NB fan at something around 642,000RPM.
  4. FIBRE+
    FIBRE+ Minimodder
    27 Feb 2005
    I dunno what the temp was but...
    I was working on me comp one day and had removed the cooler to re-seat it or summin, the cooler was left on the side and I went off to get my lunch. I then come back about half an hour later and instinctively turned the pc on, then went away to hunt for somthing in the garrage, I came back a few minutes later to a black sreen and re-membered what I had been doing :duh: :waah:
    I turned the pc off for half an hour, come back crossed my fingers and pressed the button... cmon, pleeeeasse!......
    ..... It works!!!! :clap:
    Bloody lucky, it still worked perfectly fine somehow and carried on using it for another 6 months :D
    Supposudly my hardisk was at 13124144525oC or summin using the hdd tool the other day :hip:
  5. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    I think we've all done that before Fibre+, I did it with an old Celeron a few months back, still ran XP, just a bit slow... :p
  6. Firehed
    15 Feb 2004
    I never have...but then again I always automatically pull the plug whenever the proc is seated without a cooling mechanism in place.
    I've had the HD thing happen before too. Just a tad warm... core of the sun or so. At the time I could have used it... winter in Vermont with a window making up 60% of your wall and being the last in the heating circuit isn't too fun.
  7. striker289
    striker289 What's a Dremel?
    22 Jan 2005
    my friends 2600+ barton hit 93c i shut it down and had to rebuild his pc. Between the heatsink getting bumped and the cpu fan sucking hot air from the PSU it was a bad situation.
  8. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    ditto Firehed. Worst i ever did was a P3 1.2 to 79C by not plugging the sink in, and 99c on a 1GHz CU-Mine without the fan on to see if it was passively stable.
  9. guy
    guy What's a Dremel?
    20 May 2004
    only 72C on my 2400 Mobile @ 2.5, just didnt have heatsink seated right, still works fine.
