Hey. This is my first post, about my first mod lol. I want to make my side panel into a hinge panel so it easy to get to the inside of my pc and just for kicks to. So what i am really looking for really is what typw of hinges should i use and how should i attach it my case. Thanks for help P.s sorry in advance if i annoy anyone
piano hinges whould work quite well, just cutt to the correct length and screw/rivet/whatever it to you case back and side (attach on the inside of the case & side). good luck
i used piano hinges on my htpc, since it has a flip top 'top' metal lid, to access the internal components, link here http://forums.bit-tech.net/showthread.php?t=93070
