Hardware Hiper Anubis
Discussion in 'Article Discussion' started by Tim S, 2 Oct 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
    http://www.bit-tech.net/hardware/2007/10/02/hiper_anubis/1
    The Hiper Anubis chassis is an interesting design that has proven controversial in our offices already. Will the case pass the Martin Test? Will the case get covered with fingerprints in the photos? Will Rich figure out how to add a front fan to the case? Answers within!
    :naughty:
  2. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    errr,no.
  3. xrob
    xrob What's a Dremel?
    31 Dec 2005
    i like the interior, just pity they couldnt keep the plain simple clean lines on the outside too, the front, top and side are hidious.
  4. iwog
    iwog Linux cursed
    14 Jun 2007
    Woo for British design. Would say engineering but i doubt this case is made in the UK :(
    I have wanted to know what the infamous Bit-Tech though of the case after i found ou tabout it a month ago. This might be my next case of choice if i can find the money for it.
  5. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    And again a anoying door...
  6. naokaji
    naokaji whatever
    8 Dec 2006
    no slide out mobotray? boooh.... the heatsink like fins on the top look dangerous (in a negative way)...
    oh btw.. can the door be mounted on either side so you get to choose to what sde it opens?
    other than that, good review... keep them comming:clap:
  7. Bladestorm
    Bladestorm What's a Dremel?
    14 Dec 2005
    <Broken record> Will Bit ever review the akasa eclipse 62 ? I can't fault the design and finish on mine, especially running pretty cheap for what it is .. A very solid, nicely performing case particularly good (imho anyway) as a base for modding. </Broken record>
  8. phuzz
    phuzz This is a title
    28 May 2004
    Why is it that it's usually the more expensive cases that have loads of points to mount fans, but don't actually come with them? Perhaps because they expect anyone spending that amount of cash to have their own preferences for fans. Anyway, maybe it would be fair to review the case with a couple of added fans as well? Clearly stating that you're expected to buy your own of course.
  9. Guest-16
    Guest-16 Guest
    We mulled it, but this is how you buy the case and that's what we review. What fans do you use then? High flow, low noise? 80/92/120? We could be here forever.
    As for styling, obviously it's down to personal preference. Personally there's only so many square boxes "with clean lines" I can look at before they get boring, and while I'm not alone in that thought I'm certainly not a majority. There was a very mixed reaction in the office (Andy from TR hates the look iirc) with it but the overall consensus after playing with it was generally positive. :)
    Removable mobo trays are hit and miss, because it may be easy to take it out and install but getting it back in is sometimes more effort than it's worth. It depends on the hardware you use and your installation technique which varies greatly.
  10. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
    The door can't be remounted, unfortunately and the heatsink fins on top aren't dangerous at all. :D
  11. naokaji
    naokaji whatever
    8 Dec 2006
    bleh about the door...
    about the fins.. well, i was just a bit concerned about that they could mark the return of cases one can easily hurt himself with.
  12. Guest-23315
    Guest-23315 Guest
    I thought it would have been aweful when I saw its price, but I'm quite glad I was wrong.
    looks like a nice case..
  13. theprodigalrebel
    theprodigalrebel What's a Dremel?
    3 Sep 2007
    You guys take some really pretty pictures.
    Very nice! /Borat
  14. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    Do the heatsink-esque fins actually do anything?
  15. Tim S
    Tim S OG
    8 Nov 2001
    I believe if you rub your head along the top of the case, it acts as a comb. ;)
  16. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    I'm not too big on the design myself, including the door, and the fact that it doesn't have enough room compared to others in the price-range. Not for me, personally.
  17. Naberius
    Naberius What's a Dremel?
    20 Nov 2006
    My god what is that, i have seen nicer looking things fall out of the ugly tree.
  18. pendragon
    pendragon I pickle they
    14 May 2004
    lol ..that made me chuckle :thumb:
    I'm pretty indifferent about this case.. nothing really says 'awesome' to me.:blah:
  19. KA-OS
    KA-OS What's a Dremel?
    21 Jan 2008
    I was foolish enough to buy this damn case before any reviews where put out . I actually like the look of it but "Buyer BEWARE".
    I thought lotsa drive bays so maybe a rad in front or a triple space res...............Aint gonna happen!!!! Every single drive bay has a support running from the very front of the case to the back of the bays. And not the thin metal ones you can snip off or fold down. !/8 inch thick solid alum. So if you want to fill them all with dvd roms or any single slot device you're o.k. .......NOT every bay is about 1/16th of an inch too narrow. Dvd roms stop dead at the face plate. Front fan mounts outside in front not behind. Thank god it has a door, cuz your build looks like crap .
    Also look at the rear fan area it is recesed into the case witch makes it even tighter in there, unless you mount it outside. Again looks like a sloppy build then.
    Lastly Tthis case is not built from the ground up like the review states. It is pieced and welded together parts of NZXT's Adamas and a Sigma case. Do yourself a favor and look elswhere. I promise you will not be happy with this case at all. "TRUST ME PLEASE!!!"
  20. CardJoe
    3 Apr 2007
    Hm. Dunno how much I agree with that. I have this case at home and, apart from the noise, it's been great.
Tags: Add Tags
