Hiper Media Chassis
Discussion in 'Article Discussion' started by WilHarris, 23 Feb 2005.
  1. WilHarris
    WilHarris Just another nobody Moderator
    16 Jun 2001
  2. Mister_Tad
    27 Dec 2002
    niiiiiiiiiiiice case, hopefully it isnt as horrificly expensive as some of the other HTPC cases, will definitely get one of these badboys to replace my antec minuet provided its cheap enough :baby:
  3. Lord_A
    Lord_A Boom baby!
    23 Mar 2002
    Very sexy, just waiting to see how much it will cost.
    It's about time I got a dedicated media PC and this case would look great with the rest of my audio/visual gear :D
  4. fathazza
    fathazza Freed on Probation
    20 May 2002
    grat looking case.
    looks much more like a dvd player than a pc :thumb:
    edit: the review was a bit short tho. And you didnt mention anything about the agp riser card. And how much space there would be for anything approaching a decent gfx card to fit in. :idea:
  5. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    This case just showed up at Scan's "today only" page, priced at £52.86.
    Not too pricey for a HTPC case with a PSU' :thumb:
  6. Stompy
    Stompy What's a Dremel?
    16 Aug 2004
    Does it take MATX boards? Some more details would have been nice.
    Case looks awesome though! If only I had £55 to spend... :waah:
  7. Lord_A
    Lord_A Boom baby!
    23 Mar 2002
    Read the review :wallbash:
  8. Guest-16
    Guest-16 Guest
    One of these and the ATI Xpress board ive got = uber HTPC! :rock:
  9. logan
    logan flashback!
    17 Aug 2002
    Case does look nice, could do with more info in the review though....
    What about optical drive? Does it take a standard DVD drive or need a slimline one? And is it stealthed or would that need to be modded? :dremel:
    The hiper website states it comes with a "Slim line optical drive to desktop IDE adaptor" Which would suggest the obvious....
    It's the only thing I'm concerned about before I throw my cash at scan today....
    edit: As for cost, the non-"today only" price at scan is only £55.08 inc vat :clap:
    Just in case you're considering it but don't want to make a rush purchase
  10. jetsetjimbo
    jetsetjimbo Up-up and away
    19 Feb 2003
    There's also a review in this months CPC (not in shops yet).
    In answer to you question Logan it can only house slim line optical drives.
    I'm very tempted by these myself but may just go for a cheap pre built dab tuner and pvr as that's all I need really and I don't know if I have the time to build and configure a slick HTPC.
  11. DaHoboFest
    DaHoboFest Banned
    7 Aug 2004
    looks like a harmon kardon piece of equipment
  12. Guest-16
    Guest-16 Guest
    It does say "laptop optical drive" in the review.
    Shame it doesnt have SATA connectors on the PSU and itll probably be a right sod trying to fit a SATA drive. You can get 90 degree data cables but i havent seen 90 degree SATA power :/
  13. logan
    logan flashback!
    17 Aug 2002
    Doh! I read it twice to check before i posted.... but obviously not very well. :blush:
    Apologies to mrhaz
  14. Guest-16
    Guest-16 Guest
    Always the way :) we all do it
  15. bigniall
    bigniall What's a Dremel?
    10 Nov 2002
    Also available over here.
  16. jetsetjimbo
    19 Feb 2003
    Ok, it's only got one explansion plate for a PCI / AGP slot on the back. Doesn't that mean it's going to be pretty hard to get decent tv-out, 5.1, wirless and a DVB tuner... :(
    Guess that's a bit much to ask of it but in my opinion a decent PVR/HTPC needs all these things.
  17. Guest-16
    Guest-16 Guest
    You can get USB2 dvb tuners iirc, you can get an ATI board (939) with onboard TV out or Epia with TV out and "decent" 5.1.. i take it you dont mean onboard ac97 :p
  18. jetsetjimbo
    19 Feb 2003
    Well not really. I'd be nice to get a good phono outputs if it was going to be completely integrated into a home cinema setup.
    There are a couple of nforce2 boards so I guess a digital signal could just be piped out to an external 5.1 processor. I've seen one with onboard TV out but i think it was a mx440 or something like that.
    What's the quality of the tv out like on the epia boards? I wasn't really looking at going for A64 just using some spare bits I have lying around. ;)
    I'll have to look into the usb tuners but it'd be nice to fit it all into the one box.
  19. planki
    planki ...
    20 Dec 2003
    you cant say that and leave us wanting to know all about this ati Xpress board, when do we get to see the reviews!!! ??? !!!
  20. Guest-16
    Guest-16 Guest
    Epia boards arent bad, but you cant get SPDIF out as well as composite which is all they have (one or other through same port). Nothing has component video out, best youll get is Svideo.
    planki - as soon as it's passed through the system mate ;) should be soon.
Tags: Add Tags
