Watercooling HIS 6970 IceQ Turbo Heat Output
Discussion in 'Hardware' started by CraigWatson, 24 Dec 2011.
  1. CraigWatson
    CraigWatson Level Chuck Norris
    9 Apr 2009
    Hi all,
    I'm in the preliminary stages of planning my liquid-cooling loop for Project Poseidon and wondering if I can get away with a single 140mm radiator for my HIS 6970 - anyone know the heat output in watts.
    I have the IceQ Turbo 2GB version if it makes any difference, and I don't plan to overclock :)
    Cheers,
    Craig
  2. Parge
    16 Jul 2010
    Yes should be fine. The 6970 is a reasonably warm card, mine used to max out about 85C, but a single 140 rad will be ok for just that card.
