Hardware HIS ATI Radeon HD 4670 IceQ
Discussion in 'Article Discussion' started by Tim S, 2 Feb 2009.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. FatMikel
    FatMikel Statistically not that fat...
    2 Jan 2008
    The problem with all those other cards that are much more for £30 more, are that they require aux power connections. For people like me, looking to upgrade my Dell, it's a no brainer. The cost of upgrading the PSU, plus the cost of the card, is not equal to the performance gained. In cases such as this, the HIS ATI Radeon 4670 IceQ (or the Turbo model which I got for £65) is a clear winner.
  3. DarkFear
    DarkFear What's a Dremel?
    14 Oct 2003
    Vrooom! :lol:
    A worthy card for a budget system
  4. popcornuk1983
    popcornuk1983 Cake or Death?
    3 Sep 2008
    I bought a ASUS 4670 a short while back and was impressed with the performance it gave me. I don't play on a resolution any higher than 1280x1024 and the card can handle most games on high settings at that resolution. It may no be able to compete with the cards that were on the test, but I stand by my choice and am very happy with this cheap little number
  5. Tim S
    Tim S OG
    8 Nov 2001
    I don't disagree... the 4670 isn't a bad card if you don't have an aux connector - it's the fact you can get so much more for not that much extra in terms of cost. The 4830/4850 will last a lot longer... but of course, they're more expensive. We'd recommend going for a cheaper 4670 if you need a card without an aux connector - otherwise get the 9600 GT, as it looks like the current sweetspot at this price point.
  6. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    A bit optimistic there :)
    Anyway, Isn't it a better idea to do these kind of cards in a roundup, instead of an article? I really don't see the point of this review, brilliantly written as it is :p
  7. FatMikel
    2 Jan 2008
    Plus £60 for a good PSU. So that's £90 extra. Do you get £90 worth more performance? Doubt it.
  8. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    i'm really impressed with the 8800GT performance here, was good to see it alongside the 4850 holding its own. mine cost me £160 a year ago and its proved to be one of the best hardware choices i have ever made.
    what also strikes me is how much performance you can get at this end of the market for what is really a very small amount of cash. its great to see the hardware end of the market becoming more accessible to more people, just seems a shame that usability on the software side of things seems to be nosediving fairly spectacularly as Joe pointed out yesterday
  9. [PUNK] crompers
    20 May 2008
    read tim's post properly mate :)
  10. Hustler
    Hustler Minimodder
    8 Aug 2005
    "otherwise get the 9600 GT, as it looks like the current sweetspot at this price point."
    Spot on, i think its the most underrated card out there for the price.....
    I play COD4 at 1280x1024, 4xAA, and pretty much all the other settings maxed out and get a constant 50-60fps.
  11. SBS
    SBS What's a Dremel?
    6 Jan 2009
    Really don't like to slate your reviews as they are generally excellent but this one seems to have missed the point of this card slightly.
    Not sure how you can slate this thing as poor 'Bang for your Buck' without seriously considering power consumption. This thing takes as little as 3 watts (three!) when idling and uses considerably less power at load than the 9600GT or GSO. Even with modest use for a year this thing will work out cheaper than either of NVidia's offerings.
    Then in the conclusion we hear that the 4670's main problem against it's competitors is it's poor performance at 1,680 x 1,050 and higher - you don't say? Really, who expects to game at those sort of resolutions for £55-£60 (GIYF). The low money market this is targeted at aren't magically going to have £150+ high res monitors to use with it and potentially not even a PSU with a 6pin adapter (another £50+ upgrade). At 1280x1024 and 1024x768 this thing is more than adequate for current games (hell, it got me through GTA IV with an E7400) and really having used 9600GT's and 4830 in numerous recent builds, when you factor in the IceQ's silent running as well I don't see any great advantages to either in low end builds.
    I appreciate that coming from a gaming standpoint this thing does generally drop 2-4fps against the 9600GT but is this worth an extra £15 (for a solution with a similar customised cooling, cheaper 4670's are available)? Think about it as an extra 20-25% in a budget, erm, budget and it's hard to justify. If you're throwing together a machine for £350-£500 there are so many other places that cash would be useful.
    Hightech do also offer a (modestly) overclocked version of this card branded as the Turbo which also be found for under the £69 Novatech are selling this for.
  12. FatMikel
    2 Jan 2008
    Eh? You'd need a new PSU for the 9600GT as well. For the market it's aimed at (silent PCs, quick upgrade to IGPs), the HD4670 is the best card. Even better overclocked.
  13. [PUNK] crompers
    20 May 2008
    first off:
    "I don't disagree... the 4670 isn't a bad card if you don't have an aux connector"
    secondly:
    "We'd recommend going for a cheaper 4670 if you need a card without an aux connector - otherwise get the 9600 GT, as it looks like the current sweetspot at this price point"
    He agrees with you, get a 4670 if you dont have an aux connector, BUT if you're power supply is good enough the best price to performance ratio is a 9600GT. Get it?
  14. FatMikel
    2 Jan 2008
    I never said that the 9600GT wasn't the best card price/performance wise, but that's aimed at a different market.
    No need for the attitude.
  15. [PUNK] crompers
    20 May 2008
    not sure what you mean about attitude, it just seems you were so quick to defend your graphics card that you didnt read the post and missed that Tim was actually agreeing with you. i was merely clarifying.
  16. FatMikel
    2 Jan 2008
    And you seem so quick to defend Tim that you didn't read my posts and immediately assumed that I was disagreeing with Tim's thoughts on the 9600GT. I was merely clarifying.
    And when I say attitude, I mean the "Read Tims post properly, mate" and the "Get it?".
  17. [PUNK] crompers
    20 May 2008
    hmm i think you may be backtracking a little there.....
    in any case im sorry if i came across rude that was never the intention (note the smiley face). thread hijack over.
  18. Gremlin
    Gremlin What's a Dremel?
    31 Aug 2008
    So glad i didnt buy this! it was only $30 AUD before shipping cheaper than the Sapphire 4830 i picked up and id have to say thats money well worth it
    after seeing this it makes me really glad i didnt get it i dodged a bullet there!!
  19. popcornuk1983
    3 Sep 2008
    Completely agree that there is better value cards out there for a few extra pennies.
    Sigh......just wish I wasn't a skint student with a cheapo PSU :blush:
    Still, can play fallout3 and bioshock on me gorgeous samsung telly so im happy as :D
  20. Mongoose132
    Mongoose132 Duckmad
    23 Aug 2007
    Page 5 - Fallout
    We know from experiance that Fallout 3 is a very memory bandwidth hungry title, but even here the slight increase in >>memroy<< clock of the HIS Radeon 4670 IceQ
    What is this memroy you speak of!? where can I get it? :p
Tags: Add Tags
