Hardware HIS HD 6970 IceQ Turbo 2GB Review
Discussion in 'Article Discussion' started by arcticstoat, 16 Sep 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. Xir
    Xir Modder
    26 Apr 2006
    Good to see that the card is quieter than stock, though the factory overclock is very modest.
    I've been thinking of buying either the HD 6970 2GB or the GTX 570 1.3GB...but looking at the reviews over the last few monthhs and considering I'm "only" playing @ 1920x1080, I just cannot justify the priceleap over a factory overclocked GTX 560 Ti.
    Not that these are bad or undesirable cards, their price is just too high above middle class cards while their performance isn't.
  3. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    *Hugs Asus HD6950 flashed to HD6970 (unlocked bios)*
    Identical performance to this card all for £200.
    The HIS HD6950 Turbo that Overclockers have on pre order for £219.99 looks like a good deal:
    http://www.overclockers.co.uk/showproduct.php?prodid=GX-042-HS
    Assuming it can clock as well as the HD6970 it will be around 5% slower clock for clock but cost £55 less.
  4. xMathiasD
    xMathiasD What's a Dremel?
    15 Mar 2009
    i don't like the look of that card.. reminds me of the cards 4/5 years ago!
  5. andrew8200m
    andrew8200m Multimodder
    4 May 2009
    Thats the idea and they sold like wild fire back then ;)
    A fantastic looking card in person too, much nicer than the pictures :)
  6. sakzzz
    sakzzz Minimodder
    13 May 2009
    That cooler brings back good memories....:D
  7. Christopher N. Lew
    Christopher N. Lew Folding in memory of my father
    23 Apr 2009
    Thanks for including Folding@Home figures, though surprisingly low. I guess you weren't using the v.7 which should give higher PPD with AMD cards
  8. KiNETiK
    KiNETiK What's a Dremel?
    7 Apr 2011
    I notice the PNY XLR8 Liquid Cooled GTX 580 OC in the comparison benchmarks but I can't remember seeing a stand alone review of this card on Bit-tech. Will we be seeing a review of this card as well soon?
  9. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    Yes indeed, it's being finished off at the mo.
  10. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    That's what I like to see. A hsf that vents all of the waste heat out of the case.
    At least that's what I'd like to see. Those hsf's used to.
    Ditch some of the ports and have better vents imo. I don't really want any waste gpu heat dumping in the case.
  11. l3v1ck
    23 Apr 2009
    Double post
  12. Farfalho
    Farfalho Minimodder
    27 Nov 2009
    Just what I thought! I remember seeing this graphics somewhere on the internet but not on bit-tech. Well, choppy chop, off you go, show us the review :p
  13. dunx
    dunx ITX is where it's at !
    1 Sep 2010
    Why, oh why don't they have a plug-in DVI port on a separate backplane ?
    dunx
  14. james888
    james888 What's a Dremel?
    13 Mar 2011
    "The large heatsink is aided by an equally large 80mm radial fan, which blows air down the length of the card. The heatsink covers not only the CPU but also the card’s 2GB of GDDR5 memory modules via an aluminium contact plate. Meanwhile, the VRMs are fitted with a separate heatsink, which is placed underneath the lower fan intake to take advantage of indirect airflow. "
    Isn't it a gpu on a graphics card? Either a spelling mistake or I am mistaken.
  15. longweight
    7 May 2011
    Sounds like a really good card but my god it's just so ugly!
  16. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Damn nice come back by HIS but if has anything to do with looks I'd give it a 0. The only time a HIS card looked god though was when the old XT800 was around
  17. salesman
    salesman Minimodder
    29 Apr 2007
    I happily paid $50 less for my 570, besides that this card would be too much for my setup. I always liked HIS coolers.
  18. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    900 clk with that aftermarket cooler, kind of low.. my gigabyte 6970 oc2 comes 920 stock and it does 950 oc'd.. it has a nice cooler like that though
    doesn't make a difference though at 1080p.. it plays everything up and only pulls 220 watts more over idle
  19. trig
    trig god's little mistake
    10 Aug 2006
    looks good, but not making me regret my msi twin frozr 3 for $300 at all...
  20. Boscoe
    Boscoe Electronics extraordinaire.
    5 Jan 2010
    Old school shiz
Tags: Add Tags
