Hardware HIS Radeon 7870 IceQ 2GB Review
Discussion in 'Article Discussion' started by brumgrunt, 24 Jul 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. aLtikal
    aLtikal 1338-One step infront of the pro's
    7 May 2008
  3. alex101
    alex101 Geek
    14 Jun 2010
    "With only 2GB of memory and a 256-bit memory interface it struggles at higher multi-monitor resolutions"
    Hmmmm.... having 'only' 2GB of RAM isn't causing the low fps. Surely the 690 proves the statement incorrect by being faster than 3GB cards? Surely the low fps is due mainly to the 256-bit memory interface?
    Otherwise great article
  4. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    The issue of the HD7870 struggling at multi monitor resolutions is more to do with a lack of raw GPU grunt than anything else. A 680 overclocked (1185/6800) can quite happily hang with an overclocked HD7970 (1125/6600) - based on my own tests, despite both a memory bandthwith and quantity deficit.
    In single card configs you will nearly always run out of GPU grunt than anything else at this sort of resolution.
  5. Nikumba
    Nikumba Minimodder
    29 Aug 2001
    Good review, but could you not also include its last gen version eg the 6870 so can get an idea of how they compare, as now I will have to look at other websites and try and find which is better etc.
    Kimbie
  6. rollo
    rollo Modder
    16 May 2008
    as others have said people on this forum have tested 2gb vs 4gb at multi monitor res and its gpu grunt nothing else that it lacks
  7. Jipa
    5 Feb 2004
    The IceQ-coolers really kick major arse. Currently running a HD 6970 and boy is it quiet.
  8. Matticus
    Matticus ...
    23 Feb 2008
    Performance shows twice in the score, rather than performance and features.
    Seems a decent enough card, I keep thinking I should upgrade but nothing yet has really sold me. I think I need to run into a game that my 5850 just simply cannot run regardless of the settings before I bother upgrading :)
  9. dolphie
    dolphie What's a Dremel?
    6 Jul 2012
    Omg, faster than a 680 for £239? Nice!
  10. Valinor
    Valinor What's a Dremel?
    30 Oct 2010
    But doesn't have the same number of compute units - so the 7870'll be faster if they are at the same frequencies. Marginally so perhaps, but that's what people pay for when they're spending £200+ on a graphics card, not the massive jumps you get in the sub-£150 segment of the market.
  11. dolphie
    6 Jul 2012
    And perhaps temp/volume difference too.
  12. dangerman1337
    dangerman1337 Minimodder
    2 Sep 2010
    While this does look nice, the same shop listed has the MSI 7950 Twin Frozr 3 running for an extra thirty squids: http://www.overclockers.co.uk/showproduct.php?prodid=GX-148-MS&groupid=701&catid=56&subcat=1673 (also at Scan last time I checked). While this 7870 is already overclocked you can probably give the 7950 an extra boost as well which would lead it into giving extra framerate (assuming you'll want to void the warranty though) or even then you can strech slightly further you can grab a 670 (scan: http://www.scan.co.uk/products/2gb-...gddr5-gpu-965mhz-boost-1045mhz-cores-1344-2xd, OCUK (week offer though): http://www.overclockers.co.uk/showproduct.php?prodid=GX-182-OK&groupid=701&catid=1914&subcat=2294).
    TBH I think this review hasn't benched enough games (unless Bit-Tech are doing other things that may have limited time for this review). Not trying to diss on Bit Tech BTW but I don't think this 7870 isn't as good value as it looks like IMHO as the final ratings. Then again I can see this being a good card for those who are limited by the form factor/size or looking for high performance with lower power consumption/noise levels.
  13. John_T
    John_T Minimodder
    3 Aug 2009
    I think that's who it's really aimed at - power without the noise. Peace & quiet is worth paying a (reasonable) premium for.
  14. pbryanw
    pbryanw Minimodder
    22 Jul 2009
    I agree, just a shame that it's a triple slot cooler and not double (I have a micro-ATX motherboard and no room to spare. I wish I'd paid a bit extra for a standard board).
  15. dolphie
    6 Jul 2012
    Yup I've already paid a premium for it with my case and current fans, my current (be quiet!) CPU cooler, and an SSD. The volume was even a big reason why I bought an HD5870, because it's so amazingly quiet. You get used to quietness too, like a distant gentle breeze rather than an ever present buzzzzzz. I'll definitely have to pay attention to volumes whenever I upgrade again.
  16. Player-x
    Player-x What's a Dremel?
    21 Jan 2008
    Got this card to replace the aging 4870 IceQ i had in my HTPC, and man do i love it its even more silent then the old one during gaming.
    And unhearble during XBMC use.
    I picked this one because besides that its pretty silent, what more cards are, it also blows the hot air strait out of the case.
    Also even do its a 3 slot cooler, I could still install a Xonar DSX next to it in the 3th slot
  17. johnnyboy700
    johnnyboy700 Minimodder
    27 May 2007
    How come when I google HIS Radeon 7870 IceQ the card that come up looks completly different from the one in the review?
    The page linked to the price brings up the card in the review but its waay more than £239.
  18. johnnyboy700
    27 May 2007
    Doh!
    Ignore me I'm dumb.
Tags: Add Tags
