News Hitachi paves the way to 24TB disks
Discussion in 'Article Discussion' started by Lizard, 26 Nov 2010.
  1. Gradius
    Gradius IT Consultant
    3 Feb 2009
    SSD will takes around 5 to 10 years to drop the price where the HDD is now.
    I use both, first for speed needs, and the other for capacity of course.
    However the smaller is the write, more sustained to errors it can be.
  2. Jehla
    Jehla Minimodder
    8 Jan 2010
    Am I too late to drop a "24TB? We will NEVER need more storage than that, no way no how"
  3. SpAceman
    SpAceman What's a Dremel?
    1 Nov 2010
    Never say we will never need that much storage. There was a time where a 1GB drive was more than enough for the home computer. Eventually 24TB will be the minimum.
  4. Chicken76
    Chicken76 Minimodder
    10 Nov 2009
    What do you guys mean? What makes this amount of data 'risky' in RAID5?
  5. feedayeen
    feedayeen What's a Dremel?
    18 Jun 2008
    It is not the specific amount that is risky, but the probability of failure increases.
    The probability that a hard drive will fail is largely independent on it's size and capacity, the repair time from a failure however is linear with the capacity of the drive. Larger drives take a longer amount of time to repair, for a 1 TB drive, it can take 3 or 4 hours easily with constant read and writes across all drives in the system, this step would be extremely stressful on the remaining HDDs. These remaining drives may themselves be damaged or on the verge of failure because they are of the same design as the first failure and they've undergone nearly identical usage cycles. This is not a good situation and if you expand the capacity to something close to 10TB for each drive, the repair time from the first failure could be close to a week. If a second drive fails during the repair period, you now have 2 dead disks, depending on how the controller stores the data, everything could be lost.
  6. Boogle
    Boogle What's a Dremel?
    8 Mar 2002
    Repair time isn't linear with capacity. The 24TB drives will be a lot faster than a 1TB drive. Unless the controller itself is already maxed out - I doubt the repair time will be significantly higher than it is now. Maybe 24hrs at most. I've also found the HD failure is practically random, just because one in the set has failed, doesn't mean the others will - they can last for years while others in the same batch fail within a few months.
  7. shanky887614
    shanky887614 What's a Dremel?
    13 May 2009
    i think you guys are slightly mis informed if you think we will never need that size
    what this means is most video and audio formats will come in raw uncompressed formats which are of a higher quiality
    let me give you an example
    a 24min video of anime in an mp4 container (with video in an mpeg4 and audio in lc-aac)
    it will be arround 51MB (this is with a 300kbps bitrate)
    the raw video data size for this low quality video comes to 3770mb
    if you work with raw videos,pictures or music you will find 1tb of space does not go ver far at all
    this is why most people who want the best quality have massive data stores of over 10tb+
    240mins or 4 hours will be 37gb
    in other words this equals 125mb a min
    or only 8000min/133hours on a 1tb hdd
    i havent got very many dvd's only 100 but this would take up 1.5tb
    2 hours = 120mins * 125 = 15,000 * 100 = 1,500,000mb or 1.5tb
  8. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    Our household data storage is currently around 8tb. This is movies, files, photos, music, important documents, games, backups and random stuff.. I would welcome these HDD's :D
  9. nissanskyrice
    nissanskyrice Terminally Lazy
    10 Jul 2006
    would need to use something like RAID 60 to even come close to safe... Now theres an expensive pRon server.
  10. cgthomas
    cgthomas Cpt. Handsome
    20 Oct 2009
    Backing up that amount of data will be a bitch to start with - we need a more reliable storage media.
    SDDs are a step in the right direction, but still too expensive for the general public
  11. kHAn_au
    kHAn_au What's a Dremel?
    12 Dec 2005
    on consumer kit sure raid 5 isnt great with 2t disks. if you have decent SMART/error prediction then youre much safer.
    I agree though, they will have to crack the unrecoverable error rate nut seriously hard before even 8tb disks will of practical use.
    I'd suggest doing internal mirroring in radial arcs of the spindles- it would allow for faster reads and writes as rotational latency would be divided by the number of mirrors. The controller s would have to be far smarter and robust too. Plus an enterprise grade SSD cache would be needed.
    I could handle all that if it meant a reliable 8TB (24/3) disk though...
  12. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    I wonder if there will be any fun and games making those interact with older versions of Windows with older LBA, especially given the fun with a "mere" 3tb disk, that I believe Bit-Tech covered back in June.
  13. Th3Maverick
    Th3Maverick What's a Dremel?
    23 Aug 2006
    That's all fine and dandy, but with all of that extra space for buffering and swap, I have but one question...
    Will it play Crysis?
  14. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Late to the party and HDDs have very little effect to a games performance
  15. bobwya
    bobwya Custom PC Migrant
    3 May 2009
    "paves the way" = 20 years to market (if at all)
    Get real folks... :)
  16. Farfalho
    Farfalho Minimodder
    27 Nov 2009
    Do want
  17. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    i got 3 2TB drives and i got 500gb left, all those HD1080P movies and HD series take a lot of space! I wanted to get rid of my movie/series collection wall to make room for other stuff. I'm half way so I need another 3 drives to convert my complete collection.
    The result is a 2mx3mx20cm (hxwxd) collection gets stuffed into a 12x12x10cm size. Thats what i call saving space!
    So a 24TB drive is welcome :)
  18. 1-0-1
    1-0-1 Nothing interesting to put here.
    8 Jan 2009
    ... and consumers have been saying that ever since anything remotely 'radical' came out. If I am not mistaken a certain biggish corporation doubted the fact we will ever need computers to start of with.
    What I see here not 25TB only but the potential of SSD pricing being toppled, having cheaper and bigger storage available, new hardware adoption in the enterprise and small business sector coming directly or indirectly out of Hatachi's research and obviously all the other endless potential we cannot possible know about.
    Not only that but it is a little now fact the amount of (useless) data that can be stored is directly proportional to how much storage one can afford (and how fast your internet connection is) :naughty:
    Too bad home products (or which I know about) has no proper compression or deduplication mechanism. The business sector does not really have that problem - get this: 800GB server de-duplicated and compressed size is just under 400GB. That is a full backup and the incremental after this is just pathetic small making near continuous backups a very true and cheap reality (done with VEEAM Backup and Replication).
    I think the problem as you mentioned is we using roughly the same storage technology from production storage, archiving, home use and backup (except Tape).
Tags: Add Tags
