Windows hl2 help
Discussion in 'Gaming' started by finboz, 25 Sep 2005.
  1. finboz
    finboz What's a Dremel?
    11 Aug 2004
    has anyone got past the room in anticitizen 1 that has lots of security and shuts you in while your shot at from ceiling, cause im struggling here, there is a button at far side but nothing happens when i press it???
  2. keir
    keir S p i t F i r e
    5 Oct 2003
    You'r asking if people have complete'd HL2?
    im sure loads of us have, I have for sure. post some screenies of where your stuck it'll re-fresh our minds :)
  3. acron^
    acron^ ePeen++;
    15 Oct 2001
    dont remember that bit at all :/
  4. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    So long ago now, can't remember that bit.
  5. Ben
    Ben What's a Dremel?
    11 Aug 2003
    well if im thinking of the right bit it should shut down the lasser beams (in that room) and that canon (anticitizen) gun on the roof then a loads of gards rush in on you.
    edit: also dont let the man with you die.
  6. Firehed
    15 Feb 2004
    Yeah... you can't set off anything or else the button doesn't work. You have to dodge all of the laser beams on your way there. Jumping on the crates and pipes and whatnot... I'm assuming you just sprinted thru and tried to hit the button while watching your screen go red...
  7. finboz
    11 Aug 2004
    yup thats exactly what i did, thanks for the tip ill try and get to the button more carefully :rock:
  8. Lost.Soul
    Lost.Soul What's a Dremel?
    26 Oct 2004
    I think there is a long corridor secured with "energy wall" somewhere near this "laser room " -> there are two big statues in it. So grab them with GGun and use them for climb to one of the big pipes... Then its easy to get to the end of that room...
  9. finboz
    11 Aug 2004
    woot the freeman is on his way again, thanks for the help guys it's much appreciated.
  10. Dhamon45
    Dhamon45 What's a Dremel?
    7 Oct 2005
    I'm using a ati mobility radeon 7000 igp graphics card to try and play HL2. My problem is that when i try to start HL2, Steam pops up a little window that says the game is loading. Then it just goes away and nothing happens. All of my other system stats are well above the recommended requirements. What is wrong, and how do I fix it?
