Windows HL2 - No Console
Discussion in 'Gaming' started by [DE]FreD_S, 11 Aug 2005.
  1. [DE]FreD_S
    [DE]FreD_S Certified Specialist of Awesomeness
    6 Jan 2002
    Anyone encountered this and know a solution to the problem? I've got it enabled in the advanced keyboard section and even if I manually alter the config.cfg nothing happens when I press the assigned button. I don't want to play multiplayer, just SP and spin off a bit...
    And before y'all start b****in me - yes I tried the steam support forum but I haven't been activated by the moderators yet so I can't post there :wallbash:
    Cheers
    Fred
  2. Firehed
    15 Feb 2004
    bind "`" "toggleconsole"
    is that in your config?
    because as many people don't realize, that key needs to be shifted for the tilde, otherwise it's just the backwards appostrophe thing (or accent grave I suppose)
    If you have " bind "~" "toggleconsole" " in your config, you'd need to hold shift and then hit the `~ key
    also - the key isn't broken or anything, is it?
  3. [DE]FreD_S
    6 Jan 2002
    Thanks for the help, I've tried the "~" key, but that doesn't work either. I finally got access to the steam support forum and they suggested to ind "F1" to toggleconsole, which worked. Seems it's an issue with the keyboard layout you use, as only Europeans seem to have that problem.
    Thanks alot for your help anyway - much appreciated :thumb:
    Cheers
    Fred
  4. Firehed
    15 Feb 2004
    That'll do it... I'll assume that ` and ~ aren't mapped to the same key (~ being the shifted `) on Euro. keyboards then... as that would be most logical.
  5. ou7blaze
    ou7blaze sensational.
    5 May 2003
    I guess it depends where you are but aren't you using the QWERTY layout?
  6. Go4t
    Go4t i
    13 Dec 2003
    european qwerty and us qwerty have the characters other than letters/numbers in different places
