Graphics HL2 stuttering/lag...
Discussion in 'Hardware' started by Highland3r, 16 Nov 2004.
  1. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Hl2 seems to random stutter and lag... fps drop a little it just lags, like the machine is paging... (but no hdd activity)
    Increasing the res seems to make it worse, so having to stikc with 1024 atm. Changed drivers to the 4.12 betas which helped a little, and boosted the average fps... Still dips to ~ 20 randomly from ~60-120....
    Anyone getting simialr? Supposdly its an issue with half life itself....
  2. Shadowspawn
    Shadowspawn Another hated American.
    1 Jul 2002
    I'm getting lags when a new enemy is coming up. Like just before I turn a corner. In my case I'm sure its my system, as my 1.6 gig and 9800 pro just aren't enough anymore.
  3. CyberSol
    CyberSol 1337 Pants
    18 Oct 2004
    no troubles here
    3.0ghz p4 ht 800mhz fsb
    ati 9700pro 128 mb
    weseterndigital 120gb hdd 8mb cache
    1 gig corsair memory.
  4. LoopyJuice
    LoopyJuice Astronomical
    24 Jun 2001
    As far as i can tell, its the auto savedgames, when you enter a new area of get past a certain hard part it does an auto save which seems to lag out the game for a few seconds, everyone who i've spoken to has had it but its nothing major
  5. TheCleaner
    TheCleaner Back again...
    5 Jul 2004
    its caching thats making it lag.. basically my fps may remain high.. but for instance, the first time fireing a gun.. the sound stutters, as if its being cached/extracted/uncompressed.. remeber, all the files hl2 is working with is in that big gfc file, so each time a new texture/sound is needed, it has to be extracted..
    more ram would lessen the problem (since more can be initially cached) but its a problem on valves side
  6. Langer
    Langer Jesse Lang
    24 Jan 2004
    I'm not having any troubles. runs great...fantastic game
  7. Firehed
    15 Feb 2004
    Most likely autosaving, I've noticed it a bit too.
    Anyone else notice the load times are *really* long? Or is it just me?
  8. Highland3r
    25 Jul 2003
    Ok kewl, was told it was on valves side :) The lag is just as described as well, 1280 was unplayable last night (laggy) so will drop down and try again. Will try adding some more ram too...
    Strange thing is, my housemates ti4200/2.6 p4c/512mb is running it nice and "smooth"!
  9. quack
    quack Minimodder
    6 Mar 2002
    I found entering one section of the game completely locked me up for a bit... and both the video and audio went crazy. After about a minute it gave me control again. Dunno if that's anything to do with autosaving or not.
    Just before I stopped playing last night the sound started going choppy too. Definitely not related to autosaving.
  10. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    Yeah that's it, in the Steam release the .gcf isn't uncompressed, whereas it is in the retail install - so retail users shouldn't see this problem. Just ripping the .gcf files doesn't work either, apparently - I wonder what the solution is.
  11. quack
    quack Minimodder
    6 Mar 2002
    Interesting. Surely Valve must've known this might be a problem on less than bleeding edge PCs?
    So far I've only noticed one area where it went wild, but I'm not that far though the game yet!
  12. Kameleon
    29 Apr 2003
    I've no idea if your issue is the same problem, but the game lagging briefly every time it caches a new sound/effect/animation almost certainly is down to the compressed .gcf.
  13. quack
    quack Minimodder
    6 Mar 2002
    I'm just hoping it was a one-off. If it keeps happening I won't be a happy ducky.
  14. Highland3r
    25 Jul 2003
    Well it all seems ok now... dropped the textures down a notch and its miles better. Still get lag someitmes on auto save, and some caching of sounds etc... but other than that nice and smooth :D
    And man, does the ant grav gun ROCK!
  15. Chr!s
    Chr!s What's a Dremel?
    21 Apr 2004
    Not Autosave its a problem with the game itsself and is happening on hundreads of users systems, Top end and middle ground.
    Read the Steam HL2 forum. Post "Audio Stuttering"
    Valve know about it and are working on a fix.
