Notebooks Hmm Mackbook
Discussion in 'Hardware' started by cire9753, 22 Aug 2006.
  1. cire9753
    cire9753 What's a Dremel?
    16 Aug 2006
    well im getting a macbook (i need it for school) and i was wondering if i should spend the extra 100 bucks for 1gb of ram vs then regular 512. i want to do some grapics ect on it and i have photoshop. thanks
  2. [1N0V471V]
    [1N0V471V] What's a Dremel?
    27 Feb 2006
    No, do not. Instead, order it with 512MB and upgrade it yourself to 2GB for $100
  3. cire9753
    16 Aug 2006
    where can i get 2x 1gig laptop ram for 50 bucks a pop?
  4. cire9753
    16 Aug 2006
  5. woodshop
    woodshop UnSeenly
    14 Oct 2003
    you can get it for $189
    http://www.newegg.com/Product/Product.asp?Item=N82E16820146125
    DDR2 5300 should be correct for a macbook
    [edit]
    you need Notebook ram thats desktop ram.
    [edit2]
    if you allready got 1GB in a single stick then just get another single stick and it won't cost that $189
  6. cire9753
    16 Aug 2006
    yeah now the question is G.Skill or patriot (same price)
  7. cire9753
    16 Aug 2006
    g.skill is getting better ratings
  8. [1N0V471V]
    27 Feb 2006
    G.Skill IMO, but either one wouldn't be bad...
  9. cire9753
    16 Aug 2006
    well
    i got my macbook 2ghz stock ram and i ordered a gig of patriot ram ts commin tomorrow and i will order another stick (1.25 gigs > 2 gigs) if im not satisfied with 1.25 gigs of ram. btw this laptop rocks would reccomend if you got the moolah
  10. lamboman
    lamboman What's a Dremel?
    25 Jul 2006
    gskill
  11. cire9753
    16 Aug 2006
    yeah the gskill just went up in price right before i bought so i though id take a gamble with patriot
  12. cire9753
    16 Aug 2006
    installed worked perfect thanks for saving me some cash
  13. woodshop
    woodshop UnSeenly
    14 Oct 2003
    glad we could help
