Hmmm odd
Discussion in 'bit-tech Folding Team' started by ThunderBob, 8 Nov 2009.
  1. ThunderBob
    ThunderBob New Member
    19 Sep 2005
    Well you never can tell with CPU overclocks.
    I have 4 Q6600s atm (2unused atm) and here is what happened.
    Q6600 No.1 has a 1.325 default power setting,Runs at 25degrees.
    Q6600 No.2 has a 1.215 default power setting,Runs at 35degrees.
    No.1 will overclock to 3.0GHz stably at 1.4 and runs at 33degrees idle.
    No.2 will overclock to 3.2GHz stably at 1.315 and runs at 45degrees idle.
    Room temp was 68degrees.
    WELL. I would have thought at standard settings that the one that requires the lesser power (1.215) would run cooler as its not pulling as much juice. Hmmm you never can tell.
    I tested and reseated the HS/F and it made no difference. The 2nd CPU always ran about 10degrees higher but always required less power. Odd to say the least :)
    As an afterthought. The 2nd CPU folds better and more stably.
  2. StreetSam
    StreetSam New Member
    30 Aug 2005
    Nice sub-ambient cooling you got there :D
  3. ThunderBob
    19 Sep 2005
    Hey it was early!!!
    The CPUs are Celsius and the room is in Fahrenheit :wallbash:
