Modding holesaw -- cut from outside or inside ??
Discussion in 'Modding' started by mushky, 21 Aug 2003.
  1. mushky
    mushky gimme snails
    24 Mar 2003
    im just about to use a 114mm holesaw to cut 2 holes in the top of my case. would it make much of a difference if i cut from outside or from the inside?
    just about to do it so any comments extremely welcome.
    thansk guys
  2. Pflumingo
    Pflumingo givem the bird.
    17 Jul 2002
    cut from the outside... that way your rough edges will be on the inside, and easier to shave off without screwing your finish.
  3. Dad
    Dad You talkin to me?
    15 Apr 2003
    Right... Cut from the outside - however, if you're repainting, it doesn't really matter. Just cut the hole and use a round file or emery paper to smooth the cut.
  4. kong
    kong cnc-guy
    24 Feb 2002
    And if it is a steel case, I strongly recommend some lube. A bit of WD40 or even 3 in 1 will help keep the saw cool, and stop the lid of your case from discolouring due to the heat.
  5. mushky
    mushky gimme snails
    24 Mar 2003
    yeah i thought that. it was so much easier to line up the pencil marks on the inside though lol, ok mate, thanks :)
  6. mushky
    mushky gimme snails
    24 Mar 2003
    Wow, people post fast round here :) thanks guys.
    nice tip dude, thanks :)
  7. FragaGeddon
    FragaGeddon What's a Dremel?
    14 Aug 2003
    Also try clamping a piece of would to the inside if possible.
    Something that you don't mind getting cut up,like a piece of scrap wood.
    This might prevent rough edges from happening on the inside.
  8. Dad
    15 Apr 2003
    Plus, is it is aluminum, it'll help prevent the panel from bending if you apply too much pressure.
  9. Virtblue
    Virtblue What's a Dremel?
    10 Mar 2002
    and mask off the area with masking tape so the center bit does not slide
  10. Pflumingo
    17 Jul 2002
    Best tip yet, Drill the center hole from the inside (and make your marks on the inside) first... use a small pilot hole to set the center, it'll keep the arbor from wandering too.
  11. mushky
    mushky gimme snails
    24 Mar 2003
    woo !
    2 x 120mm holes in the top of my case ready for my new thermochill :)
    i had my girlfrined dress up in gloves + an overcoat holding it down :D
    she was really scared of the sparks it was soooo cute :)
    thanks for the help guys, it was really useful. cheers ;)
  12. tk421
    tk421 Idiot.
    15 Jan 2002
    when i use my holesaws in steel, i start the cut from the outside, let it go about 3/4 the way through, and flip the piece and finish from the inside.
    I know it sounds like too much work, but ive always gotten better results that way.
    and then you just take the dremel and a sanding drum with a coarse belt on it, and sand away the little knife-like edge that the holesaw left.
