Modding Holey Processors
Discussion in 'Modding' started by Digitalblueshift, 18 Mar 2002.
  1. Digitalblueshift
    Digitalblueshift What's a Dremel?
    12 Feb 2002
    Ok judging by the disaster mods thread it is going to be a bi*ch to do this but...
    I have three procs a 486dx, p100 and a cyrix 133 and i want to make keychains out of them, but i am curious is there any way to drill a hole through the ceramic for the loop, but still leave the chip functional, sort of a trace dead spot?
    I doubt it but i thought it would be cool to have a working proc beside my working ram on my keys.
  2. UnLoadeD
    UnLoadeD What's a Dremel?
    2 Jan 2002
    I doubt you'll find a place to drill and it still work, most people cut the pins off for a key-chain. If you dont, they wont last long anyway and you wont be wanting to put you keys in your pocket, thats for sure. If you have the chips made of drill-bit-kryptonite you might consider soldering a loop onto one of the corners, I've seen quite a few like that and they look pretty nice.
  3. stewe151
    stewe151 Stress Personified
    9 Mar 2002
    the stupis things are almost impossible to drill through :mad:
  4. Marzupial
    Marzupial What's a Dremel?
    29 Oct 2001
    when i saw this thread all i thought was:
    "Holey Processors, Batman!"
    hehe
    :rofl: :rofl: :rofl:
    Just me being stoopid again! :eek:
  5. LoopyJuice
    LoopyJuice Astronomical
    24 Jun 2001
    the only thing i know of that has managed to cut through a cpu is an Ultrasonic Drill, i think the Cheese Man got it done with on at uni, not sure tho :rolleyes:
  6. Phrozenpenguin
    Phrozenpenguin What's a Dremel?
    11 Dec 2001
    Have you got any pics of the soldered one? Given me some ideas...:D Yeah i can remember someone did get it drilled with some fancy expensive drill.
  7. LoopyJuice
    24 Jun 2001
    yeah it was an ultra sonic drill, it involved water ad things and a resovior being built around the lil bt u wanted to drill, maybe you could do it with a diamond tipped drill and a lot of oil if you drill slowly, not sure th ough;)
  8. brianpodskalny
    brianpodskalny ladies night!
    3 Nov 2001
    kinda realted
    if youre in the US you can buy burnt out athlon processors for 2 bucks from newegg.com
  9. sco0by
    sco0by Mmm pie.
    12 Dec 2001
    I tried drilling thru a burnt out Slot A 1ghz athlon with the following tools (in the order I tried them):
    Dremel
    18v Cordless Drill
    600w Bosch Drill
    1200w Makita Percussion Hammer drill (hammer turned off :p)
    Big-ass bench drill
    sledgehammer (pending!)
    I tried HSS drill bits, masonry bits, tungsten carbide bits, using WD40, oil, even butter! :rolleyes:
    Nothing worked! - I now have a slighly dented and very scratched - yet holeless athlon back in my drawer - having given up on the whole affair.... until guy fawkes night that is :cool: *evil grin*
  10. LoopyJuice
    24 Jun 2001
    just gimmie 10 mins, a 14lb sledge hammer and a 6 inch nail and i'll put a hole in her for ya ;)
  11. Digitalblueshift
    12 Feb 2002
    maybe i should get this moved, there goes 1 titanium coated 3/32" drill bit, hmm what next, i think im gonna slice off the pins and bond a little loop to the surface and then put my chain through that.
    I I only had access to a high pressure water jst that should make a clean cut, il see what my local glass and ceramics shop would charge and if they can cut a hole in it for me.
  12. sobriquet
    sobriquet What's a Dremel?
    4 Jan 2002
    i'd just use some epoxy putty and a little metal eye.
  13. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    has anyone tried a drill bit for ceramic? :p they make em for glass too.. heres a hint, take a nail and put a small chip where you want the hole to keep the bit from walking.. :)
    -scoob8000
  14. UnLoadeD
    2 Jan 2002
    there's a whooooole long thread about this in disaster mods forum, have a look there 8)
  15. Digitalblueshift
    12 Feb 2002
    I know take another loooooong look inthe thread in disaster nmods.
  16. stewe151
    9 Mar 2002
    i wonder if a laser engraver will work. my grandma has one, ill take mine over there to next time i go and see if it works.
  17. LoopyJuice
    24 Jun 2001
    heh why not use a thermic lance? my dad used to use one of those at some aluminium extruding factory for cutting poles the size of lamp posts in half bet that would put a scratch or 2 in your chip :D
