Case Mod - In Progress Holy Grail of ITX (2 GPUs on ITX)
Discussion in 'Project Logs' started by NameAlwaysInUse, 5 Aug 2016.
  1. NameAlwaysInUse
    NameAlwaysInUse What's a Dremel?
    11 Dec 2014
  2. Vault-Tec
    30 Aug 2015
    And another one with shopping lists and no actual modding.
  3. NameAlwaysInUse
    11 Dec 2014
    Holy Grail of ITX
    Moved to first post
  4. Vault-Tec
    30 Aug 2015
    I am cool and it's the forum rules mate.
  5. Nexxo
    23 Oct 2001
    Project Logs rule no. 2:
  6. NameAlwaysInUse
    11 Dec 2014
    Such a strange rule but I moved the post I made the same day ;) just to keep you guys happy
  7. Vault-Tec
    30 Aug 2015
    I don't think it's stupid. It stops the forum from becoming ad spam heaven.
    We want to see modding, not adverts.
  8. NameAlwaysInUse
    11 Dec 2014
    Holy Grail of ITX
    But then it's not a log... it's a normal post... for a post you don't have to open different threads. To make you happy they could close this subforum ans just create one thread called "modding pics" and there everybody can post his project :)
    There was no complain at my last three logs so I don't care :)
  9. NameAlwaysInUse
    11 Dec 2014
    Modified driver... now I can enable SLI :) next stop benchmark
  10. NameAlwaysInUse
    11 Dec 2014
    Benchmark Time!
    All without bridge
    Sli disabled
    Sli enabled
  11. Guest-16
    Guest-16 Guest
    I don't really understand why you'd buy a mini ITX board and go SLI of two 980 Tis fpr $600 a piece, rather than just spend $1200 on a Titan X or go mATX and have 8 DIMM slots?
  12. NameAlwaysInUse
    11 Dec 2014
    Cause everybody can do this? cause the MATX Cases which allow me to internal watercool the PC are to big, cause its not a challenge, cause I love ITX, cause people can ask questions like "why you dont use a Titan X", cause more power than a titan x, cause I got the cards before Titan X was released, and much more :D
    P. S. which MATX got 8 DIMM?
  13. saxovtsmike
    saxovtsmike Minimodder
    12 Aug 2008
    SLI on an itx board, interresting Idea, but where do you get the pcie lanes from for the second gpu... Any kind of riser card involved that splits a pcie 3.0 X16 slot into two x8 ?
    I understand the Part of the Rules section where it´s no Mod when there is no modding done yet.
    At least it´s not a "just look what my sponsos just sent me" Pictures thread full of Thermaltake P5 Cases and their watercooling kits.
    On OCN it´s solved in a pretty simple way, Sponsored Builds have their own section...
  14. Vault-Tec
    30 Aug 2015
    It's some sort of splitter ribbon IIRC
  15. NameAlwaysInUse
    11 Dec 2014
    @saxovtsmike and on OCN I am not posting in the sponsor section... what is that telling you? ;)
    Yes I use a risercard from Supermicro servers to split the x16 to x8, then you need a BIOS for your MB, which can handle the splitted lanes and at least you need a modified driver, which allows you to use SLI on boards, which doesnt support SLI.
    @Vault-Tec: I got your point about the first post! I didnt want to post a buying list, it was just to start the build log. After the software and SLI things are solved the preparation of the case will start! =)
  16. NameAlwaysInUse
    11 Dec 2014
    Last score was with software emulated bridge.
    This screens now are with virtualized blabla and the second is with a real bridge
  17. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    How is it stupid?
    It is self explanatory and keeps things focused on the modding...instead of one pic and a heap of attitude.....
  18. NameAlwaysInUse
    11 Dec 2014
    Cause it's in the logs section ;) log = work in progress
  19. Vault-Tec
    30 Aug 2015
    Work in progress means work. So far all we have seen is a case in bits (doesn't count as modding) and a few screen shots of 3dmark.
  20. NameAlwaysInUse
    11 Dec 2014
    Mod just means modified/modification... the drivers are modified :) but the case is in the milling machine at the moment (work in progress ;))
    If that's a problem for you keep out of this thread :) I am annoyed about the notifications with your name. Seems that you just try to play Forum police and push your post counter :S but hey you missed my last 3 logs :D
