Electronics home built arcade cabinet storage thing...?
Discussion in 'Modding' started by HumanMan42, 30 Jul 2006.
  1. HumanMan42
    HumanMan42 What's a Dremel?
    14 Mar 2004
    I have an idea to build a arcade cabinet that'll let me store and use all my retro consoles. I will have storage for games, cords, and consoles alike. It will also deature one of my older pc's running linux with (if he actually does it), a coustom GUI. Anyways, i have one question about this....
    i want to have the real controlls on top. the classic arcade stick and buttons. I looked online, and found them. And how to's. They keyboard one was the one i was leaning twords. but it was written really poorly. Is this a good way to do it? is there an easy way to do it thatll work. I know how to solder with a small amount of knoledge about cuircitry. my spelling sucks,but oh well.
    thanks for any help.
    casey
  2. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
    You cannot unify the controllers from multiple consoles with incompatible interfaces. So for the older consoles you'll simply have to emulate the games of have drawers to stow the controllers in.
  3. Cabe
    Cabe What's a Dremel?
    14 May 2002
    what you could do is hack up a controller for each system, then have one of those printer data switchers between the buttons and the controllers.
  4. crazydeep74
    crazydeep74 What's a Dremel?
    25 Jul 2005
    What he said, and Isolate all the consoles control cables from each other. Diodes?
  5. HumanMan42
    14 Mar 2004
    afterthough
    i was thinking about it. i think i might make it so i can have all the systems hooked up to the tv in one fashion or another (so i can play the real system with the real controller), and then for the emulation part of it, get 4 computer arcade joysticks.
    somthing like this
    http://cgi.ebay.com/New-USB-Arcade-...8QQihZ017QQcategoryZ31215QQrdZ1QQcmdZViewItem
    mod that into the where they should be, they are usb, call it good. i might just make a coustom java/flash/vb fullscreen-amajig for the interface in windows, because i dont know that much about linux and dont know if what i would get would have drivers that are supported under linux.
    any more thoughts, ideas?
    i need to get a tv now, with composit/stereo in. craigslist here i come!
    casey
  6. devenfore
    devenfore LANCandy
    8 Jul 2003
