Scratch Build – In Progress home made all in one desktop
Discussion in 'Project Logs' started by weed2all, 15 Feb 2013.
  1. weed2all
    weed2all modder
    24 Oct 2011
    hello...i am a user of bit-tech and i see many awsome modd and scratch build and now i want to do my own all in one pc with touch screen
    hardware in use
    mobo: rampage 3 gene
    cpu: socket 1366, i7 980
    vga: evga gtx 460 1gb ddr5
    ddr 3 : kingston 3x 4gb 1600mhz , 3x2gb 1600mhz
    hdd : 2x320 gb raid 0 , 2 tb WD
    cooling: corsair h100
    psu : corsair tx 650M
    monitor in use is a lg 19" standard 1280x1024 with elo touch screen
  2. AverageNinja
    AverageNinja Almost an EpicNinja
    6 Aug 2012
    So, where are actual pictures, progress on the build etc.? This is not really a build log, but a proposed build.
  3. weed2all
    weed2all modder
    24 Oct 2011
    monitor frame is almoust done...now to test monitor to see if it work
    sorry for my bad english...i dont speak english for about 10 years now...
  4. weed2all
    weed2all modder
    24 Oct 2011
    testing monitor to see if anything is working...
  5. Elenos
    Elenos What's a Dremel?
    11 Feb 2013
    Looking good so far! I suspect weed2all's posts are stuck in a moderation queue.
    I want to see how you mount the pc on the back of the screen :)
  6. weed2all
    weed2all modder
    24 Oct 2011
    my ideea is to make a base for monitor and inside mount my pc...
  7. weed2all
    weed2all modder
    24 Oct 2011
    i will use this pci-e extender on my project to put the video card to ocuppies a small space...
  8. weed2all
    weed2all modder
    24 Oct 2011
    i will do anythyng tomorow
  9. weed2all
    weed2all modder
    24 Oct 2011
    a litle update...i dont have much time to work on my project
    an update to bottons control of the monitor
    spacers to install the motherboard
    installing motherboard
    video card supporte
  10. weed2all
    weed2all modder
    24 Oct 2011
  11. weed2all
    weed2all modder
    24 Oct 2011
    that is all for now...update soon...i will mount de corsair h100 cpu cooler and hdd
    then i will make a base to seat my pc...
  12. weed2all
    weed2all modder
    24 Oct 2011
    comment pls...any ideea...i wait for it.10x
  13. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    keep it up, you're going in the right direction, thought maybe you shpuld turn the gpu around so that it can get fresh air from the outside instead of pre-warmed air from the other components?
  14. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    interesting project!
    i'll grab some ideas for my next builds :)
  15. weed2all
    weed2all modder
    24 Oct 2011
    hy there kelmannen...i have thinking that on the gpu, but it will occupies a lot of space because the pci-e extender...the right way a think is this...thought i will istall a few small fans maybe 60x60 or smallest for the air circulation
  16. weed2all
    weed2all modder
    24 Oct 2011
    i want a computer smallest as i can take...
  17. kelmannen
    5 Feb 2011
    yeye, got you there :) the intake fans might be a good idea but 60mm fans do often have very bad noise levels :/
  18. Inches
    Inches What's a Dremel?
    19 Jan 2013
    If you flip the GPU you should be able to mount some cross flow fans in the chassis that can be controlled by the GPU board to keep it cool. That way you could take the cover off and slim it down some. But like kelmannen said I'd definitely flip the GPU, even then you could show it off a little
  19. White-Fox
    White-Fox What's a Dremel?
    11 Feb 2013
    seems nice :) and just a question, how well those riser cables work?
  20. weed2all
    weed2all modder
    24 Oct 2011
    i will try on a 60mm and smallest like 40mm fan...after testing i will decide wich i use...for now i will resume to finish entire case...i think to use acrylic to make the protection of entire pc...
