Modding Home made molex remover :(
Discussion in 'Modding' started by webbyman, 16 Apr 2005.
  1. webbyman
    webbyman Hax.
    7 Oct 2004
    im trying to sleeve my psu, but i havent got a molex remover, and im finding it difficult to even remove 1 pin :worried:
    does anyone know how to make you own? *rather than buy one :( *
    any guides, help, ideas welcome :thumb:
  2. Cookie Monster
    Cookie Monster Multimodder
    27 Aug 2003
    theres a thread in here some place about it.
    I did see someone using the ink part of a biro. but you need to cut a 2 slits in the top for it to work i think. its here
  3. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Look in the mod guides, but a slim jeweller's screwdriver will gently bend the barbs in so the pins slide out, then bend them back to replace.
  4. webbyman
    webbyman Hax.
    7 Oct 2004
    thanks so far... :thumb:
    i tryed that one, as i remember seeing it ages ago... the only bad thing is i failed at making it work :sigh:
    but im going to try again later :D
  5. GigantoR
    GigantoR What's a Dremel?
    21 Jul 2004
    I found one at Fry's for like 3 bucks. Works too.
  6. Firehed
    15 Feb 2004
    some guy cut slits in a small straw (like a coffee stirrer) and it worked fairly well IIRC.
  7. TX297
    TX297 Hey guys have you heard of seenly?
    28 Oct 2003
    Go to Radio Shack and buy a 2.5mm mono audio plug. Cut the top off it and remove the guts. Done. I have 2 floating around here somewhere...
    And there is a forum post around here somewhere, the search tool is your friend ;)
    Hope this helps,
    -TX297
  8. Ben '71 1200
    Ben '71 1200 What's a Dremel?
    16 Aug 2004
    if you look down into the connector, there are two springy 'legs' on each pin of a molex connector. I've been pretty successfull just pushing these in with a 1mm precision screwdriver, if you push them in enough, they get stuck in the slots which they protrude from. They need to be pushed out again when you reassemble the connector
  9. deiol
    deiol What's a Dremel?
    14 Jun 2001
    yeah, i use a jeweler's screwdriver too
  10. c.u.later
    c.u.later What's a Dremel?
    16 Apr 2005
    i always manage with a flattened out paperclip. worked so far and is easy to use
  11. sadffffff
    sadffffff Minimodder
    20 Oct 2003
    take a cheapo bic pen apart like in this picture:
    then take the ink cartridge and push it over the pin in the molex connector, next simply pull it out the back of the connector since the ink cartridge has pushed in the barbs on the pin. the ink cartridge is much better than a coffee straw since it is very ridgid. always worked great for me.
  12. sadffffff
    20 Oct 2003
    now that i look at it, my method is the same as the one in the link, except i dont cut slits or anything and its always worked for me.
  13. NoMercy
    NoMercy What's a Dremel?
    23 Nov 2004
    I've used the ballpoint pen trick many times, though only for removing pins in fan-adapters, can't seem to fit it over the socket pins... alas there the most common.
  14. webbyman
    webbyman Hax.
    7 Oct 2004
    i have done that with the male one :naughty:
    just the female ones im having trouble with :worried: :duh: :waah:
  15. Kobalt
    Kobalt What's a Dremel?
    26 Aug 2003
    The small screwdriver method works best for male and female :thumb:
  16. bwgames
    bwgames Minimodder
    6 Dec 2004
    N'thed.
    Small screwdrivers (just pick up a set from a car boot) are only £1 or so for a pack, and bloody handy :D
  17. ehrnam45
    ehrnam45 What's a Dremel?
    5 Jul 2004
    I got the combo male/female adapter from jab-tech.com for about $4. It works great on molex drive connectors. I don't think I tried it on the ATX power adapter though.
  18. jpaturzo
    jpaturzo What's a Dremel?
    25 Mar 2005
    I had some thin copper shim stock laying around that I cut into thin strips and bent into "L"s. Worked great on the 4 pin molexes and the ATX connector.
  19. poissonpilot
    poissonpilot What's a Dremel?
    12 Feb 2005
    if you use a jack 3.5, I think you will have a molex remover for nothing
    but I never try this method ( I, will try it this week because I'm modding my acrylic case)
    see you soon ;)
    :rock:
