Networks Home made patch cable
Discussion in 'Hardware' started by modding-monkey, 23 Jan 2005.
  1. modding-monkey
    modding-monkey What's a Dremel?
    29 Jan 2004
    Hi every 1,
    Ok hers my problem. For some reason my backup server (XP Pro) wont connect to my network using my home made patch cable but it will using a ready made cable but my home made cable works on all of my other XP Pro computers.
    The nic in the backup server is a - 3Com Etherlink 3C905C (I did get it for £1.99 on eBay so do u think it could be the card?)
    If you have any ideas please let me know. And if u need any more info please ask.
    Thanks very much
    :thumb:
  2. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    I think it is your card, I have a few (nicked :worried: ) flat grey patch lead from school (which they use for headphone systems) and they work on all of my computers except for one, use a normal cable and it works no probs. It is most likely a hardware problem or limitation, I think its unlikely that the computer can tell what cable is what.
  3. modding-monkey
    29 Jan 2004
    Yeah.
    School is a good source of parts/cables :worried: :D
    Oh well I will have to keep it hooked up with a ready made cable. :blah:
    Thanks! :thumb:
