Case Mod - In Progress Home Made Water cooling Case(DIY Fan Controller )
Discussion in 'Project Logs' started by rakesh_sharma23, 18 Oct 2008.
  1. rakesh_sharma23
    rakesh_sharma23 Member
    2 Sep 2007
    My home made Transparent Case with home made Water Cooling
    Please tell your comments about it.
    Thanks
    Rakesh Sharma
    MY PC:-
    AMD Athlon X2 4000+
    ASUS M2N-E
    2-GB DDR2_SDRAM 667
    160-250-400 GB Sata HDD
    MSI ATI R3450 256MB DDR2 Graphice
    Creative 7.1 Audigy Value
    Philips TV-Tuner
    Overclocking and temperature view:-
    Snuffles likes this.
  2. ry@n
    ry@n Well-Known Member
    31 Aug 2005
    WOW! Got any more pics of the build stages of the WC and case? I really want to see how that WC goes together! With some cable management that would be soo much better.
  3. rakesh_sharma23
    2 Sep 2007
    Thanks I will try to do some cable management.
    I have hade the water block with Aluminum Northbrige heat sink with acrylic sheet. Full coper Radiator is from old Oil cooled Machinary from local scrap yard.My pump is made from old printer head motor (HP-640 inkjet) and some plastic molded pumping unit.
    Since in small town like mine, it's hard to find a DC PUMP("forget about Branded water cooling kits"). so i made it one my self. It can pump 20 liters of water in 53 sec. at 12v dc.
    I live in Jodhpur, India. It's a hot place average room temp is around 35C. Since i am not having any type of room cooling, just a room fan.
    So my pc use to run at very high temp at normal box pack Cpu heatsink and fan, about 65c at normal running.
    This high temp inspired me to do some thing...and you all can see what i came to.
  4. Cheapskate
    13 May 2007
    Air to water heatsink conversion.:thumb:
    Oil cooller.:thumb:
    Wiper/washer pump.:thumb:
    You win the Cheapskate seal of approval.:D Not only is it all salvaged, It looks very good.
  5. Frenkie
    Frenkie Lets mod the world!
    3 Jul 2006
    As said before, the cable management is realy needed. If you can, sleeve the cables you cannot work out of sight. And the top DVD player; paint it black as the rest is also black. For the rest, very nice work. I bet Jodhpur does not have many PC stores :)
  6. Monkeyboy
    Monkeyboy Member
    13 Dec 2003
    wow, that's impressive. i love the water block. :rock:
  7. rakesh_sharma23
    2 Sep 2007
    Thanks to all
    I am working on cable management. I am looking for black cable sleeve in local market, but what i got here is just old yellow calbe sleeve used in Electric motor winding. And heat shrink sleeve is also not available.
    But i am thinking out something to be used as cable sleeves. I have used it in my pc have a closer look to the cables comming out from SMPS. I ahave used black ribben and wounded it around the wires.
    Have a look:-
  8. sethnmalice
    sethnmalice New Member
    21 Jul 2007
    I think its very impressive, case looks great, home made watercooling is brilliant :).
  9. rakesh_sharma23
    2 Sep 2007
    thanks Mr. Sethnmalice
  10. brinkz0r
    brinkz0r New Member
    15 Dec 2006
    This is why I haven't made a full acrylic case yet, it becomes way too messy! It's gonna be hard to do some cable management that makes it all look clean.
  11. rakesh_sharma23
    2 Sep 2007
    Here are new updated pic of my rig. With new full copper homemade cpu water block and motherboard water block. with some cable management of fan cable . And side panal fan and power connector brackets.
    hope you like it.
  12. ModMinded
    ModMinded Are you throwing that away?
    26 Aug 2008
    The wire management is greatly improved. I especially like the fan header/contacts. I'm going to be doing something like that for the fans/leds on my door using copper foil strips, or terminal strips, since I couldn't find something premade easily. What's the 2 pin connector for? It says HDD led, but I figure you recycled it from spare parts and you wired some fan leds?
  13. rakesh_sharma23
    2 Sep 2007
    Thanks Mr. ModMinded
    Yes two pin "say Hdd led" is powering fan leds.
  14. Cheapskate
    13 May 2007
    I like the new blocks too.
  15. rakesh_sharma23
    2 Sep 2007
    Thanks Mr. Cheapskate . And how about cable management
  16. ModMinded
    26 Aug 2008
    Hey Rakesh (aka Mr.Sharma23), I think you have duplicate logs up - 1 in modding and 1 in project logs... that's why I couldn't find my previous posts, I had put it in the other one! You should probably put them together into one... saves you and the moderators a bit of trouble.
    If you're looking for ideas of what else to do, might i suggest painting the i/o shield area so its not just gray metal? Of course that would mean disassembling everything. I still would like to see the front optical drives matching (paint/vinyl dye), and if you could get some sleeving/ribbon to wrap around more of those cables, it would look a sleeker.
    How does the water cooling work? By that I mean what temperatures are you getting and can you compare them to before water cooling?
    PS, no need to call me Mr... :)
  17. rakesh_sharma23
    2 Sep 2007
    Thnaks Mod Minded . As per temperature diference there is no change in CPU tempersture or so , but Mb chipset temp came to 36 c, with MB waterblock.
  18. rakesh_sharma23
    2 Sep 2007
  19. rakesh_sharma23
    2 Sep 2007
  20. Fyve
    Fyve New Member
    4 Mar 2008
    The fan connectors for the side panel is really clever! Nice work :D
