Case Mod - In Progress Home Made Water cooling Case(DIY Fan Controller )
Discussion in 'Project Logs' started by rakesh_sharma23, 18 Oct 2008.
  1. Langer
    Langer Jesse Lang
    24 Jan 2004
    aluminum + copper = very very BAD idea.
    It'll cause a galvanic reaction which will lead to corrosion and potentially flow blockage and pump failure
    Apart from that. Great work - you have a very fine set of skills here mate. Good job.
  2. Djayness
    Djayness phwupupupup
    7 May 2008
    This is awesome! Ghetto mods are in style im guessing haha, trendy trendy.
  3. rakesh_sharma23
    rakesh_sharma23 Minimodder
    2 Sep 2007
    Thanks Djayness
  4. rakesh_sharma23
    2 Sep 2007
    With request from many members about galvanic reaction in my VGA block. I have removed my GFX block and now working on full copper block , till then
    Some New updates
    1.
    New PUMP gift from a DIY fan from Goa, India ...Cool AC 220V Pump. New tubes and a drain outlet tube added with a T- joint . SMPS also modded with a relay base switch for pump, so pump starts and shut down automatically with PC.
    Two Seagate 500 GB 32MB buffer Sata HDD in RAID0..
    A recognizable difference in system Speed. Now i believe that RAID do works.
    SYSTEM
    unknowngamer likes this.
  5. Sushi Warrior
    Sushi Warrior What's a Dremel?
    20 Mar 2009
    You got some bubbles there ;)
  6. Fisher.
    Fisher. partially impartial
    21 Jan 2009
    Don't mind those, it's just concentrated AWESOME:thumb:
  7. unknowngamer
    unknowngamer here
    3 Apr 2009
    Respect due (and rep)
    I'm finding it hard going just making a diy acrylic case and I've got access to some good tools.
    top marks for making your own water kit.
    I like the way your cd/dvd & 3 1/2" drives levetate (not bolted in )
  8. stonedsurd
    11 Mar 2009
    You, sir, are full of WIN! :clap:
    I'm a lazy Indian - buying off-the-shelf kit for looks. :worried:
    You take it a whole new level!
    Where do you live in India? I'd honestly like to meet you when I get back home (if you're around the North). :)
    I think I caught a glimpse of this build on techenclave, but this is the first time I'm giving it a proper look and I am VERY impressed. :thumb:
  9. DonT-FeaR
    DonT-FeaR I know what a fk'n Dremel is ok.:D
    23 Jul 2008
    wow. thats really cool... kinda speachless.. lol
    very clever
  10. rakesh_sharma23
    2 Sep 2007
    Thanks everyone..
    1. To Mr. unknowngamer all optical driver are bolted on from other side.
    2. To Mr. Stonedsurd .I live in Jodhpur, Rajasthan and you are most welcome to my place.
    badders likes this.
  11. rakesh_sharma23
    2 Sep 2007
    Look What i got in Mail Today
    Cool...............
    Will try some Serious OC ...And guess what will be my next upgrade?
    Yes It will be Phenom II ..
  12. rakesh_sharma23
    2 Sep 2007
    After upgrade to Biostar board I found that GFX card is not getting proper air flow from side panel fan cos card is now placed in bottom pci-e 16 slot resulting increase in temp of GFX.
    So decided to do something. Cut the side panel and fitted an Aluminum wire grill. And placed two Foxconn 92mm fan.
    But these fan are very noise in my wc setup. Got to do something…..searched my work place found a 5w thermo-resistance used in Xerox machine to temp control huge 240mm 24v fan.
    So designed a 1-3 fan pin extender with two connectors are controlled by this thermo-resistance. Resuling a quite fans…..
  13. bagman
    bagman Minimodder
    18 Apr 2009
    wow what is the next thing you are going to make, your own rad?
  14. stonedsurd
    11 Mar 2009
    I wonder if Cheapskate is looking at this and getting ideas :hehe:
    Oh and please Mr. Sharma, I'm a kid. You mustn't call me mister! :p
    Nice update, although I'm looking forward to the video card waterblock when it comes :)
    I'll be sure to get in touch with you when I get back home! :thumb:
    EDIT: Wow, I just realized that I punctuated every line with a smilie. Few things get me this excited.
  15. rakesh_sharma23
    2 Sep 2007
    Hi I am back with some updates on my Homemade transparent PC and Wattercooling kit.
    New Small and Improved water friction Cpu Block. (Upto 3C temp drop above older block)
    New MOSFET Heat sink for Biostar TA790GX-128M (help me to take more juice of my CPU via voltage mod)
    USB Tv-Tuner installed Internally (since had no Extra PCI slot for Tv-tuner cards)
    Have a look
    Thanks
  16. rakesh_sharma23
    2 Sep 2007
    My DIY Fully Assambled 4 Fan Controler.
    First fan in action
    Second fan in action
    Third fan in action
    Forth fan in action
    PCB with component.
    Back PCBs .
  17. disturbed13
    disturbed13 What's a Dremel?
    28 Nov 2008
    looks like you were in action as well
    a little wobbly from the massive wind? :D
    j/k
    nice btw
  18. rakesh_sharma23
    2 Sep 2007
    DIY FAN Controller Fully completed.
    I have completed the front panel for
    my DIF fan controler.
    Now fits on empty 5.25 bay.
  19. Djayness
    7 May 2008
    lol holy....he made his own pcb. Respect :p
  20. rakesh_sharma23
    2 Sep 2007
    Ok now i am onto RAM Cooler.
    Please tell me which orientation of fans is good
    Type -A
    OR
    Type -B
    This is what I am going to do.
    Install side slot stopper with spring action and 10mm foam to hold it tight with RAM slot.
    Form will give it a good grip and also help in reducing vibrations produced by fans.
    Will finish the product by 2moro.
