Networks Home network - Request timed out - file sharing
Discussion in 'Hardware' started by Roccy82, 9 Jan 2005.
  1. Roccy82
    Roccy82 What's a Dremel?
    9 Jan 2005
    Hello all,
    I have just set up a home network (or still trying to) as i have just purchased a D-LINK 504G 4 port DSL router. I have 2 clients both running XP with SP2, both connected via the router.
    At the moment both computers can browse the interent. I am trying to setup file / printer sharing. 1 computer can access the other, however the other can't get any response, just the error - request timed out. I have tried a few things, and i can't think what else to try!! :wallbash:
    Computer 1
    - IP is 10.1.1.5
    - can browse the internet
    - This comp has xp firewall (however i have disabled it)
    - can ping itself & router IP. Thats as far as it goes if i try ping Computer 2 IP or DNS i get "Request timed out".
    - Trying to access Computer 2 shared folders i get the error: \\sharename is not accessable...
    ROUTER
    - Router IP is 10.1.1.1
    - This does have a firewall on it, however it is set to "Disabled".
    - Router assigns IP's through DHCP and all clients are sent to obtain an IP address automatically
    Computer 2 - (where everything works fine)
    - IP is 10.1.1.3
    - can ping itself, the router IP, my other computer (IP & hostname), can share files folders.
    - Has McAffe security center (i have disabled all features [even shut all processes running in msconfig])
    I have tried running the setup a home or small office network wizard, on both clients, and this error still occurs. All shared folders have sharing enabled with the options "share this folder on the network"
    & "allow network users to change my files" both ticked on both computers.
    Can anyone please help with what i could try next? :confused: Or what have i missed! Thanks in advance and I do apologise for the long post but i tried to put most of the details in here.
  2. Haddy
    Haddy World Domination
    22 Jan 2002
    Does it say that you arent authorized or that its not accessable...paste the exact error it gives...
    I had similar problems with dlink before..but im old and cant remeber what the fix was....
  3. planki
    planki ...
    20 Dec 2003
    i wouldnt disable the firewall as this means that you are open to attack from the interent side of your router.
  4. Arkuden
    Arkuden mow?
    9 Jul 2004
    hmm do you have uPnP installed on your machines. I was having the same problem only mine was with a linksys router. I had to enable a few windows components to get it running but after doing a little research i found that i didnt have uPnP installed. Seems to work fine for me now.
    good luck
  5. Roccy82
    9 Jan 2005
    Thanks for that guys all working now, i had to install more windows components now all ok
