Networks Home network upgrade
Discussion in 'Hardware' started by nimbu, 2 Sep 2019.
  1. GeorgeK
    18 Sep 2010
    I've bought quite extensively from NetXL (or their partner company yay.com) for Unifi gear so might be worth a look to see if you can save some money there. Also check on eBay - in the past I've bought from NetXL's eBay shop at a cheaper price that on their own website. Also I've had excellent customer service from them when an item I ordered was out of stock.
    Mister_Tad likes this.
  2. nimbu
    nimbu Well-Known Member
    28 Nov 2002
    Cool,
    I also have some Cisco gbit Poe switches, just need to figure out how to reset them and turn them into dumb ones.
  3. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    Google for “Cisco (model) password recovery” and “cisco (model) factory reset” and it should be right at the top.
  4. Mister_Tad
    Mister_Tad Super Moderator Super Moderator
    27 Dec 2002
    In which case, definitely make sure to include the "-E" AP models in your search, no need for the injectors.
    Also note if you're buying second hand or potentially old stock, older Lite and LR models are passive POE incompatible with anything but certain Unifi switches - newer models are AF though. I know you're looking at Pros, and they're all AF anyway, but worth a mention.
  5. nimbu
    28 Nov 2002
    Units have arrived. I opted to get the injectors for now. This way I can get it running without having to fiddle with the Cisco switches for now.
