Networks Home network wirh 2K Pro and XP Pro
Discussion in 'Hardware' started by Alan, 11 Dec 2004.
  1. Alan
    Alan New Member
    11 Sep 2001
    I have a D-Link router connected to a cable modem for internet access and I run 2k Pro on my desktop. I have just bought a laptop with XP Pro and am connecting to the router with a wireless access point. Internet access and connections are just peachy but I can't see the local network on either machine. I have file sharing in place, am using the same workgroup name but neither can see the other. As I understand it, the router is the problem because the hardware firewall closes all the ports and I think this is why I have no network connections.
    If this is indeed the problem, which ports should be open and, to lesser extent, how do I open them?
    Any pointers would be appreciated.
  2. Alan
    Alan New Member
    11 Sep 2001
    Problem solved. I'll try to make the next one more interesting. :duh:
  3. rooroo
    rooroo Member
    15 Jun 2003
    can you please say how you solved this, as i am having the same problems
  4. Shadowspawn
    Shadowspawn Another hated American.
    1 Jul 2002
    It shouldn't have been the firewall on the router...that controls the traffic coming and going on the WAN port, not the switched ports.
  5. Alan
    Alan New Member
    11 Sep 2001
    Apologies for the huge delay in answering. Norton Internet Security was blocking it so I added trusted computers and used the IP address range that my router uses. End of problem. :duh:
