Build Advice Home Server Build Advice
Discussion in 'Hardware' started by Serenity, 14 Jun 2010.
  1. Serenity
    Serenity What's a Dremel?
    23 Oct 2009
    Hi everyone,
    I have been looking to get a Home Server and have been looking at the one such as the ACER EasyStore or the HP MediaSmart Server
    Both systems are the perfect size I had in mind
    Acer EasyShare = 7.9" W x 7.1" D x 8.3" H
    HP MediaSmart = 5.5" W X 9.8" D x 9.2" H
    I would rather build my own however so I can easily upgrade as needed. I cannot however find any MITX cases that are of a similiar size.
    The Acer comes with an Atom 230 processor which I would liek to have something with a little more juice so will be looking at either a socket 775 or 1156 MITX boards once I have made a decision on case.
    Any suggestions would be much appreciated.
  2. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
  3. Serenity
    23 Oct 2009
  4. Combatus
    16 Feb 2009
    Not sure whereabouts you live but you need to look at some dedicated mini-ITX store's such as itxwarehouse. Ebay too usually has a pretty good selection and there's things in all shapes and sizes.
    I certainly wouldn't go for anything much smaller if you're thinking of going the 775 / 1156 route.
  5. neocleous
    neocleous Minimodder
    12 Feb 2002
    I assume you are going to install Windows home server I may be wrong and if I am this probably won't apply.
    Before you go down the mini - ITX route for a WHS the next version of the OS is going to be 64bit only so any sort of Atom Mini - ITX rig would be incompatible.
  6. Ljs
    Ljs Modder
    4 Sep 2009
  7. Fingers66
    30 Apr 2010
    Can the orginal poster please give us some more information regarding requirements, usage etc for a "home server"?
    Both the Asus and the HP run WHS but there are other choices available should you wish to build your own hardware.
    Have you decided upon your O/S yet or does the "build your own" preference precede that?
  8. Serenity
    23 Oct 2009
    Yes you are correct I would be planning on running Windows Home Server.
    As the new version will be out soon that is another reason why I want to go with a socket 775 motherboard as the current atoms wont cut it.
    In regards to motherboard I have been looking at the Intel DG45FC which is a Mitx 775 board and go with an E5200 Processor. My only concern as someone above pointed out is getting a heatsink to fit in a small case.
    I have looked at a number of sites and the difficulty is finding something that is not to long which holds 2+ 3.5" HDD bays.
    The only one I have really seen is the Chenbro M300 which is only 10" long which is more inline.
    The Lian Li PQ07 would be a lovely case but from what I see it could only hold 1 3.5" drive.
    Thanks again for your help with this.
  9. Modsbywoz
    Modsbywoz Multimodder
    14 Oct 2009
    could you not get some 5.25 to 3.5in adaptors?
  10. saspro
    saspro IT monkey
    23 Apr 2009
    It's very tight inside that Lian Li. I've built a few rigs in them & it's a squeeze (although you can fit a 3.5", a 2.5" & either a 5.25", 3.5" or 4x2.5" HDD's in the bay
  11. Fingers66
    30 Apr 2010
  12. PBear23
    PBear23 What's a Dremel?
    4 Feb 2009
  13. Serenity
    23 Oct 2009
    I have looked at the scan site and the only case which would seem to come close is the Lian Li PQ07.
    The others although being Mitx cases they are still quite large.
    So the question is for building a compact home server like those from HP and ACER would you go for the Chenbro or the Lian Li and how would you build it to hold 2 x 1TB drives.
  14. Fingers66
    30 Apr 2010
  15. neocleous
    12 Feb 2002
    I have my server built in a large Thermaltake case, I know that size is an issue for you but I wouldn't get a case too small the point of the server is to have lots of storage space and you need a case to accommodate a few hard drives.
  16. saspro
    saspro IT monkey
    23 Apr 2009
