Hardware Home Theatre PC Motherboard Shootout
Discussion in 'Article Discussion' started by Tim S, 5 Feb 2008.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    So basically all boards designed for media centers STILL fall short on the graphics front but sadly it's kind of as I suspected.
    Will you possibly be doing a sort of low end graphics cards for media centers article to compliment this at all? It would be pretty handy to have imo :)
  3. Tim S
    Tim S OG
    8 Nov 2001
    yes, there's something in the plan :)
  4. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    790g is due out shortly for those interested and should contain all AVIVo functions of the 2600 /38** series as far as i'm aware which would mean hardware bluray support
    correct me if im wrong.
    however im going to use a 3850 as my GPU of choice primarily to play the odd game on a large TV.
  5. Guest-16
    Guest-16 Guest
    Well new IGPs are arriving soon - this is also meant as a base article for us to work from :)
  6. Spiny
    Spiny What's a Dremel?
    6 Sep 2006
    I just replaced an Abit I90-HD with the Gigabyte & am really pleased. Oddly my impression was that video quality of the 7100 was better than the ATi X1250 on the Abit.
    Then again I won't add a bluray reader till they drop below around £80. If it's an issue then, I'll drop in a £40 passively cooled card.
    The I90HD wasn't Vista certified & I'd get pretty regular bluescreens, none with the Gigabyte... yet.
    The only oddity I've found is that the front panel header on the Gigabyte dosen't seem to drive the HD activity light on my Antec Fusion. Anyone else found this?
  7. Guest-23315
    Guest-23315 Guest
    Good review... Suprising to see the Asus on there. I thought it was more of a Lan Gamer board to be honest..
  8. WhiskeyAlpha
    WhiskeyAlpha What's a Dremel?
    5 May 2006
    This might sound blindingly obvious (so apologies if it comes across as patronising) but have you tried connecting the plug the other way round on the header? HDD activity lights genrally only work one way round.
  9. BioSniper
    5 Feb 2002
    Nice Tim/Bindi, can't wait :D
  10. MonkeyNutZ
    MonkeyNutZ Crysis Fiend
    5 Jun 2007
    Hmm, what's the ETA for that mATX AM2+ board?
  11. Spiny
    6 Sep 2006
    Yeah, first thing I tried. D for Diode :)
  12. phuzz
    phuzz This is a title
    28 May 2004
    So if I'm reading those results correctly, h264 content coming from either a BD or HD-DVD disk will use ~75% of the CPU at best, and yet streaming from the harddrive uses at most 50% of the CPU, what's going on here?
    What's the difference between the video coming off a shiny disk and that coming off a harddrive? HDCP?
  13. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    So, basically, they aren't quite up the job for HD movies with such low spec cpu's? or Have I missed something here?
  14. Guest-16
    Guest-16 Guest
    The disks provide much higher bitrates - you're talking 25-50GB for a movie, compared to much-much less.
    And also like you say: encryption takes up a ton of processing power. In effect - the movie studios are killing the planet.
    Yea you need a killer CPU to decode it, negating the point of an inexpensive system and video processing offloading. The next gen parts should allow low power CPU use.
  15. Rocket733
    Rocket733 Austerity - It's the only way
    27 Dec 2003
    Just curious when are the new chipsets due out? I'm looking at moving down to a sff and the Asus has been my motherboard of choice for a small gaming rig. However, I wasn't aware of the release dates for G/P45 so if they're going to be better supported delaying my build is no big deal.
  16. Guest-16
    Guest-16 Guest
    1/2/3/4 months depending on what you're after.
  17. Tim S
    Tim S OG
    8 Nov 2001
    P45/G45 are probably not coming out until later in the year (maybe as late as June/July/August). Timeframe is pretty vague at the moment for the new Intel chipsets - Nvidia/AMD are pretty close with AMD-based IGP solutions though.
    We've got very early RS780 boards in house already but are waiting for driver development to catch up with the hardware. GeForce 8200 is probably around the same timeframe too, but we don't have hardware yet.
  18. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    ya I plan on picking up that ASUS board, cant wait to get my hands on that.
  19. pejcaofrito
    pejcaofrito What's a Dremel?
    19 Jan 2007
    There's a typo on the audio's review table "24-bit / 96KHz", Gigabyte has an ADI1988B instead of the RTL 889a.
  20. fathazza
    fathazza Freed on Probation
    20 May 2002
    my hcpc is an msi 690g and amd be-2350 cpu at the moment and i have to say im really happy with it. I managed to get the cpu, mobo, and a gig of ram for just over £100 delivered and its really cost effective both in terms of power consumption and that it handles gbpvr very well as well as the odd non graphically intensive game i throw at it.
    To get hd-dvd to work glitch free i ended up plumping for a sapphire 2600xt ultimate (fanless job) which runs at pretty low power also ~60W i think.
    Im a big fan of the 690G boards tho, it is amazing how feature rich they are for under £40!
    my real gripe with a hcpcs at the moment is the lack of an effective solution to get dolby true hd, dts hd etc into the setup. There is some hope with an up coming auzentech add on board for their prelude card which should be released fairly soon but by then it will probably be cheaper to buy a stand alone bd or hd player.
    And you cant even use their full bitrate when you use analogue outs as powerdvd downmixes them for drm reasons. GRR!
Tags: Add Tags
