DIY Wood Mini Lathe Metal Axis Homemade Tailstock with Motor Drill very cheap and easy: Parts and Tools: Wood MDF 200 mm x 650 mm x 20 mm 2pcs SCS10UU 20 mm Linear Ball Bearing Motion Bearing CNC 2pcs 400 mm 20 mm Linear Rails Aluminium Alloy Profile 1200 mm x 40 mm x 20 mm Aluminium Alloy 6061 120 mm x 80 mm x 40 mm. Lathe Chuck 80 mm 2 pcs Linear shaft 35 mm x 20 mm aixs ....... More Homemade Lathe DIY Mill Miling CNC Router here:
In order to get your links to work correctly you need to use and then in the middle just the letters in the youtube URL after the "v="
