homemade water cooling for everyone ;) - january, 2006.
Discussion in 'Project Logs' started by turpija, 5 Jan 2006.
  1. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Of course, I forgot about the reserator.
    Although, it's also a pump as well, so it's more all-in-one than heat-dissipating-res.
  2. yahooadam
    yahooadam <span style="color:#f00;font-weight:bold">Ultra cs
    21 Mar 2006
    you could use the pump in the resortator to get it back into your case :) :)
    apparently the resorator pump is really unrealiable though, so its not somthing i would reccomend
  3. hellas91
    hellas91 New Member
    18 Feb 2006
    Looks amazing :jawdrop:
  4. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    I believe the Reserator is Aluminum, as is the XSPC. Something the size of a reserator, if made of copper, would be 80+ lbs, cost about 4x as much, and not cause the corrosion of the aluminum.
  5. NoahFuLing
    NoahFuLing New Member
    18 Jun 2005
    Doesn't anodization fix that problem? I always thought that that was one of the properties of anodization.
  6. andersson.j
    andersson.j New Member
    25 Mar 2005
    Anodization works, but it wears off since the water is constantly moving. And a scratch is enough to break it. So when you use a metal fitting with an anodized alu thread you will most probably break the anodization on a few spots = corrosion.
    With 10-15% Zerex it will take long before corrosion becomes a problem, but I still think it's stupid to mix metals when it's so easy to avoid it! A loop with alu and copper will last for a few years, a loop with only copper, brass and silver will last almost forever.
    If you use alu in a loop, stick to alu only and you won't have a problem.
  7. yahooadam
    21 Mar 2006
    as far as i know, anodization adds a more reactive metal on the top, so it would only be a tempory fix, as even if you didnt break it, the more reactive metal would come off eventually
  8. hllywood14
    hllywood14 New Member
    5 Jun 2006
    love it
    great mod
  9. zhangmaster12
    zhangmaster12 New Member
    11 Jun 2006
    where 2 get copper??
    this is an awsome mod. Been following it since day one. By the way, does anyione know where to get the raw copper blocks?? I might make my own blocks soon. :D
  10. BrinNutz
    BrinNutz New Member
    6 Jun 2006
    Pretty slick man...Damn good work...Wish I had the ability to do that, it'd be fun!
  11. Forvak
    Forvak New Member
    15 Jun 2006
    Very cool! This is really inspiring. What is the final weight of the case with water?
  12. turpija
    turpija New Member
    30 Dec 2005
    Well it was fun while building it, now it just sits in corner and working, just like that :yawn:
    I don't know how much it weights, but only i can say it's heavier than my 21" monitor, which is around 20kg.
    anyway, water started to get dirty (because i didn't clean all blocks properly), so i've throw it an put new one, without antifreeze. it's now transparend and actually nicer, and i put small neons so it now glows in two color ;)
  13. Denied
    Denied New Member
    28 Oct 2005
    That last photo is awesome! I have to give it to you, you have really pulled off a brilliant finish on this case. I know exactly what it's like to build something only to have it fail (like with your first resevoir)
    Brilliant work! You are an inspiration to those who aren't happy with store bought!
  14. gideon
    gideon New Member
    27 Feb 2006
    that last photot is nice looking into the tube :D
  15. Stuntman
    Stuntman Member
    22 Oct 2004
    Amazing! This project is... oh man... just so sweet! *pleasure twitches*
  16. Constructacon
    Constructacon Constructing since 1978
    12 Oct 2004
    Well done. It turned out fantastic.
    Reading your log has inspired me to get on the w/c bandwagon too. I've already purchased a 16 speed drill press and sourced copper to start milling my own waterblocks.
  17. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    best water cooling mod i've seen for ages. I havent read the entire lot i must be honest but it looks amazing!!
    oh and i thought i recognised that naked case, and then with the front panel on i was sure, hehe i have the same one, go AOpen ;-)
  18. ps90000
    ps90000 New Member
    18 Jun 2005
    Nice job!
  19. bozar88
    bozar88 New Member
    25 Nov 2006
    I'm very impressed, you have inspired me to do something similar (for graphics card only for now). Was it expensive to buy copper? I don't want to buy whole blocks, I'd rather buy 1-2mm sheet and weld a "box" with the maze inside. Top and bottom would be from thicker copper - about 5mm in order to be able to fit the connectors and make it perfectly flat
  20. jakeiswicked
    jakeiswicked New Member
    17 Oct 2005
    Amazing job! Easily one of the best I've ever seen and the fact that nothing stops you and there's always a way forward is really cool.. unlike me who still hasn't plucked up the courage to install my non-custom built watercooling :hehe:
    Its amazing work but i think all that in a nice big, new Lian Li, would look even better still, but i guess you cant have everything and the case still looks pretty dam sweet ! Superb work on the Radiator, Reservoir and blocks.. best I've seen and great improvisation
