News HomePlug announces AV2 standard
Discussion in 'Article Discussion' started by CardJoe, 18 Oct 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    LOL just remember that it all depends on the quality of your home wiring. Yes i'm looking at you +50 year old houses with hair think cabling.
  3. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    I'm still using an old homeplug socket in the one room I've not installed CA5e cable into yet, and it works adequately for everything except high def video streaming, where it starts to really struggle on fast moving content.
    We had to have our house rewired as we only had a single wire, as the return leg forming the loop had been broken by an over zealous DIY enthuiast-prior-owner who fitted countless junction boxes. The outbound leg eventually failed and we lost power, and had to call in the sparky. The degraded wire was replaced, the wiring brought up to scratch and the loop restored. The effect on the performance of our homeplug network? it became negligibly better.
    This, if it lives up to the promise, would be a great product. Far more secure than wireless and no problems with signal drop.
    Great concept but lets see how it's implemented...
  4. Snips
    Snips I can do dat, giz a job
    14 Sep 2010
    So what actually are the speeds?
  5. Silver51
    Silver51 I cast flare!
    24 Jul 2006
    We have a pair of PLT units supplied with the BT Vision box at home, probably Comtrend brand. I can hear these things over unshielded audio lines as high pitched squeals when both idling and transmitting data.
  6. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    With these things, how do you stop the signal going down the mains supply to your house and into your neighbours house? Can you password protect the network like wifi?
  7. Fabou
    Fabou What's a Dremel?
    22 Apr 2010
    You can protect your signal with a password exactly as wifi.
  8. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    I use Devolo set and the best thing is you can have one end a wireless access point. So when ever I want wlan i just pop the sucker in where I need it, even in the back garden.
  9. StoneyMahoney
    StoneyMahoney What's a Dremel?
    10 Jul 2009
    I had the Comtrend suckers that came with Bt Vision too, as did my father. Both sets developed the same problem, his almost straight away and mine after a couple of years - they just couldn't maintain a stable connection. I think it may have been an overheating problem as they'd work fine from a cold start for about 15 minutes and then go screwy. It's annoying, I have to share my media off my Mac Mini via wifi now :/
  10. Fractal
    Fractal I Think Therefore I Mod
    9 Apr 2010
    I believe the signal gets filtered out by circuit breakers (which are ultimately just inductors anyway so will block high frequency AC) so the signal won't escape your house. In fact the signal won't even get to other parts of your house if you have them on different CBs (as is standard for modern houses).
  11. Silver51
    24 Jul 2006
    Were they the white ones? Call BT support. We had the original ones which died a few weeks ago. The BT guy told us to unplug them immediately and that they would send out new ones.
  12. jaggyman
    jaggyman What's a Dremel?
    15 Jul 2010
  13. kosch
    kosch Trango in the Mango
    12 Feb 2005
    I picked up a pair of those CommTrend adapaters from my Mum when she didnt want her BT Vision box any more. Been using them to stream HD content to my PS3 as the wireless wasnt good enough as the PS3 is in a AV Cabinetm but last night one of them stopped working!
    Took one apart and something had burnt out causing the PCB to blacken and that awful smell of melt electricals. Now in the market for some new ones :(
  14. devilxc
    devilxc Biding my time...
    23 Mar 2010
    These things are a god send for rented accomodation. I've been using 200Mbps and get a transfer speed of 6Mb/s, I believe this new standard takes it up to 1000Mbps but I think transfer speeds are around 50% of the theoretical maximum (~125Mb/s).
  15. StoneyMahoney
    10 Jul 2009
    Thanks for the heads-up, looking into that now
  16. G0UDG
    G0UDG helping others costs nothing
    27 Mar 2010
    other problems caused by this system may be mains born Emc issues
  17. memeroot
    memeroot aged and experianced
    31 Oct 2009
    unshielded wires = huge transmitting ariel...
  18. Weekly_Estimate
    Weekly_Estimate Random bird noises.
    1 Feb 2010
    Logitech speakers had this problem -.-:duh:
Tags: Add Tags
