Playstation 3 Hook PS3 to Monitor
Discussion in 'Gaming' started by lcdguy, 9 Jun 2010.
  1. lcdguy
    lcdguy Minimodder
    25 May 2004
  2. Gunsmith
    Gunsmith Maximum Win
    23 Sep 2005
    that'd do the job, HDMI is basically DVI with added audio
  3. lcdguy
    lcdguy Minimodder
    25 May 2004
    cool thanks.
  4. GoodBytes
    20 Jan 2007
    I don't have a PS3.. but how do you output the audio from the HDMI?! Don't you need to extract it? or does the PS3 has other audio out source which you can use?
  5. lcdguy
    lcdguy Minimodder
    25 May 2004
    the ps3 has both HDMI and toslink Optical Audio out
  6. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    You can specify where you want your audio out to be when using HDMI.
    My own setup is HDMI from PS3 to monitor sending video only. RCA audio out converted to 3.5mm jack going to PC line-in. PC then plays audio out to my headset or speakers or both. PC also has DVI out going to the same monitor as the PS3 and VGA to a second monitor. So yes, you can send audio out to another source. I just like to show off my setup. I believe there is an optical audio out if you wanted better quality, though.
  7. lcdguy
    lcdguy Minimodder
    25 May 2004
    lol. well going to a 24: in my case is a big step down in my case i'm losing abour 70" of display area
  8. talladega
    talladega I'm Squidward
    18 Aug 2007
    That is the EXACT same thing I use. Works great!
  9. lcdguy
    lcdguy Minimodder
    25 May 2004
    i'll let you know how i make out with this. I should be getting it sometime next week.
