Horizontal Post Layout
Discussion in 'Article Discussion' started by RTT, 3 May 2005.
new post layout
  1. I like it - keep it
    17 vote(s)
    22.7%
  2. I'll live with it for the extra width
    7 vote(s)
    9.3%
  3. I hate it, please revert
    51 vote(s)
    68.0%
  1. penski
    penski BodMod
    29 Aug 2002
    I feel that it cuts up the flow of the thread, I'd happily forgo the width for a vertical layout :) (fnar)
    *n
  2. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    as many have sad i think also having the stads on the left would be better. it makes the sides really really long to scroll down.
  3. fishthecat
    fishthecat What's a Dremel?
    6 Mar 2002
    I voted "I hate it, please revert".
    It does give extra width to posts, but it adds to page height that you then have to scroll through.
    I think you should look for other ways to get extra width, maybe by removing the, mainly empty, blue bar down the right hand side.
  4. Dodge
    Dodge What's a Dremel?
    10 Oct 2003
    That would be great, not sure if it can be done though
  5. Bogomip
    Bogomip ... Yo Momma
    15 Jun 2002
    mother of god! how can i look down the thread for a certain somebodys post like this ?! all the data is sorta crammed into itself! in one endless, neverending story oftext, TEXT, TEXT.
    Maybe this is bits new problem... it all seems to revolve around text, and lots of it, all in some sort of row!
    thats how i perceive anyway :)
  6. kplonk
    kplonk What's a Dremel?
    1 Mar 2002
    Did the right had add bar go all ready? :confused:
  7. Dodge
    10 Oct 2003
    I believe its been changed to google adds from the BFG Add
  8. The_Pope
    The_Pope Geoff Richards Super Moderator
    3 Jul 2003
    actually, they're targetted, so you'll see different stuff depending on what country you live in. But the blue bar will still be there
  9. TMM
    TMM Modder
    12 Jan 2004
    i made a bit of a mock up of how it is and how it could be. you actually fit much more content with them on the left and its nice and easy to read. :thumb:
    mock up on 1024x768 (i ahd the window full screen, though i cropped the pic. and no i havent made the second one larger to make like it looks like theres more content, its the same size :):
    vertical (now) :blah:
    http://i2.photobucket.com/albums/y3/TMMTMMTMM/bitv42.jpg
    horizontal :rock: :thumb: : note that there is 5pixels either side of the banners on the right. this still leaves some "breathing room" around them, yet doesn't waste precious space
    http://i2.photobucket.com/albums/y3/TMMTMMTMM/bitv41.jpg
  10. The_Pope
    3 Jul 2003
    Thanks for your efforts - I hope people could use them as Before & After shots to decide which way to vote. Unfortunately, and again there's no way for you to have magically known this, but the buffer space around the skyscrapers isn't for decoration: it is there to support the new 160x600 skyscraper standard. Current ads are 120x600, but there will be some 150x600 and even 160x600. They will merely fill the blue space, and not encroach any further
  11. Atomic
    Atomic Gerwaff
    6 May 2002
    Really? I've seen forums with different layouts in different templates...
    edit: just seem hamish post regarding Xap. Same point as me.
  12. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    Since the ads are there to stay, this new layout is much better. It might take a little getting used to, but the increased posting space is more important :)
  13. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    I dislike it, I perfer the old layout much more.
  14. Hiren
    Hiren mind control Moderator
    15 May 2002
    I also disklike the avaters and user info spanning across the top of each post. Much prefer the old layout made threads easier to follow.
  15. TMM
    TMM Modder
    12 Jan 2004
    no Problem :).
    The ads don't bother me too much (i click on the ads from time to time, it all helps, right? ;)) Most forums i visit now have ads on the left or right, so im getting used to it.
    its just the avatar/stats bar that bothers me atm. :p
  16. Pricester
    Pricester What's a Dremel?
    25 Aug 2002
    Voted "Revert it" - the extra width is handy when browsing at 1280x1024, but the extra height to scroll through is annoying all the time.
    That said, if it's left like this, I guess disabling avatars might be a solution... not perfect, because the bar at the top of the post is still 3 lines, which (IMHO) is still too big for my taste... but better than with avatars.
  17. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    I'm 50/50 , I like the extra width but preffered the look with the av's on the left.
  18. Kronenbourg1664
    Kronenbourg1664 What's a Dremel?
    29 Sep 2002
    Add another revert vote...
  19. RTT
    RTT #parp
    12 Mar 2001
    70% wanting a revert says it all :) Reverted.
  20. planki
    planki ...
    20 Dec 2003
    Thank You!!!
    i am liking the re-design of the website and forums currently, its got a nice new fresh feel to it. However the only thing that was annoyying me was the vertical layout, now you have changed that back im all happy.
Tags: Add Tags
