Modding HOT B***H TOO HOT
Discussion in 'Modding' started by BobbyMParr, 11 Feb 2005.
  1. BobbyMParr
    BobbyMParr GameDemon
    18 Jun 2004
    I just installed 2 12" Cold Cathode Lights into my case shown here. \|/
    The Cold Cathodes made the case get too hot and the cpu fan kicked into high high speed.
    I need to find how to fix this ASAP i have 2 case fans blowing air out and then the psu fan blowing out i have to get that case temp down FAST i dont have a watercooling kit and i dont have a temp sensor just opened the case door and stuf my hand it wheeewww hot in there can you help me fix this easy? PLEASE and i prefer not to cut into my case but i will do what is needed to cool it down so i can run my cold cathodes
  2. invader crack
    invader crack New Member
    18 Jul 2004
    trying taking one of those fans and have it suck in fresh air u should see sum what of a change
  3. BobbyMParr
    18 Jun 2004
    ok ill try but i must say there is a LOT of dust in there allready
  4. CYRiX
    CYRiX New Member
    4 Sep 2004
    uhhh thats cuz nothing pushing the dust out of its collection spot.
  5. BobbyMParr
    18 Jun 2004
  6. scifi3018
    scifi3018 Member
    6 Feb 2005
    You should arrange it to have i guess 1-2 fans bloiwng air in the front, 1-2 fans (includeing power supply) blowing air out the back.
    That and try to buy a pair of good COLD Cathode Flourescent Lights (ithink) cheap ones will run hot, but good ones wont
    Also while your at it, vacum the dust out, its never good to haev in a computer, and make sure to hit up the processor heatsink, lots o dust in there normally
  7. BobbyMParr
    18 Jun 2004
    ok i switched a fan to blow air in i think its helping and as for the heatsink cleaning i tried the vacuum i need to pick up a can of compressed air for walmart
  8. TMM
    TMM Modder
    12 Jan 2004
    Cleaning that stock heatsink should be easy. If you take it off then you can pull the whole thing apart by hand and clean it with a cloth ;)
    Replacing that (restrctive) side grill with a standard wire grill will help alot too
  9. scifi3018
    scifi3018 Member
    6 Feb 2005
    yeah but if you dont have a tube of thermal compund handy taking off you heatsink to clean it is a bad ideaspeaking of which... mabye its time to do some modding today for me since i am incapacitated...
  10. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Far easier to unscrew the CPU fan from the heatsink & get in there with that compressed air spraycan.
  11. Pyrthas
    Pyrthas New Member
    17 Jan 2005
    Give you a chance to get some AS5 (or Ceramique, whatever you want) in there anyway. :p
  12. scifi3018
    scifi3018 Member
    6 Feb 2005
    :wallbash: take off the heatsink... i didnt think of that
    although for someone like me who prefers downtime to be <1min (restart ocasionally) i prefer open heart surgery to my beast unless its dramatic
  13. MRKIKKOMAN5645
    MRKIKKOMAN5645 New Member
    2 Aug 2004
    well since u already got some good adivce for the fan situation u need to download a temp monitor.. i use the one that came with my mobo but Motherboard Monitor 5(MBM5) will work just fine. just google it or im pretty sure download.com has it
