Rant hot hob + plastic toaster = bad idea
Discussion in 'General' started by Voluntary_Pariah, 19 May 2009.
  1. Voluntary_Pariah
    Voluntary_Pariah a Real Man™
    23 Jan 2009
    Right, again I come to the forum of Bit-Tech seeking help. But this time I come on behalf of another.
    My girlfriend's flat mate has managed to melt a plastic toaster into a electric hob :duh: (I have no idea what type of plastic or what type of hob). But she has asked if there is any way of getting the melted plastic off (they are in rented accomidation and are desparate to keep their damage deposit)
    Aparently they picked off as much as possible while it was still molten and apparently he is going to have another go at it later today. But I was wandering if there was a foolproof way (or preferably moron proof way in his case) off getting it all of without leaving a trace?
    Thanks, and I will pay generously with Theoretical Dollars if you provide the winning method.
    Edit: Cheap, I'm hoping that you have some wisdom on this subject
  2. Silver51
    Silver51 I cast flare!
    24 Jul 2006
    If scraping while molten was working for them, try a hot air gun (paint stripper) to gently warm the plastic again and get the rest.
  3. smc8788
    smc8788 Multimodder
    23 Apr 2009
    My method would involve turning the hob on to re-melt the plastic, then blasting it off with a pressure washer.
    I'm almost certain it would leave the hob sparkling clean, but there is a strong likelihood of collateral damage as a result.
  4. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Unlikely - I've got this type of hob and anything you melt onto it isn't coming off - your most powerful oven cleaner won't touch the stuff on my hobs.
  5. Voluntary_Pariah
    23 Jan 2009
    Ok. I should point out that I have neither paint stripper or pressure hose
    but there is an HSS tool rental place near-ish, so I think I can get almost anything that I woud need (except a new hob)
  6. Krikkit
    21 Jan 2003
    It sounds mad, but what kind of hob is it? If they're really bothered and it's a total write-off a new hob wouldn't be that expensive. Electric ones are cheap as chips anyway.
  7. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    I'm selling an electric hob having just switched to gas, you could buy it :D
  8. Nexxo
    23 Oct 2001
    Turn the hob on full tilt in a well ventilated kitchen. Leave the plastic to carbonise. It all burns off in the end.
    Obviously you do NOT use a pressure washer on an ELECTRIC hob (smc8788 is hereby nomiated for the Darwin awards). Even if you turn off all the electricity, the rapid cooling of the element is likely to cause irreparable structural damage. Else the resulting blast of steam may redecorate your skin.
  9. Voluntary_Pariah
    23 Jan 2009
    As kind (and not at all selfish) as your offer is, I think that the landlord would object if they bought the cooker without his say-so.
    TBH, I think that Nexxo's suggestion is the best. But as I won't be visiting her till Thursday, feel free to keep them coming :thumb:
    I would also like to say thanks for everyones help so far
  10. Krikkit
    21 Jan 2003
    Nexxo's suggestion is best, but if all else fails just replace it - in my experience landlord's don't give a toss about what cooker's there as long as it works and isn't knackered.
  11. quietguy
    quietguy D'orc
    4 Oct 2007
    I think the bigger concern here is getting your girlfriend's flatmate fixed before s/he reproduces. There's already a surplus of stupid, we don't need more.
  12. Nexxo
    23 Oct 2001
    You're right. Let him clean the electric hob with the pressure washer. :p
  13. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    A hairdryer may make it mailable enough to peal off?
  14. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    how the hell do you melt a plastic toaster into a hob?
  15. Silver51
    24 Jul 2006
    Or sand it off. If the landlord complains, tell them you lapped their cooker for better thermal conductivity. :thumb:
    Cupboard, capnPedro and smc8788 like this.
  16. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    What the heck is a hob?
  17. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    1: Chemicals: Acetone could work here. It depends a bit on what kind of plastic it is.
    2: Burn it! Turn the hop on full effect. Maybe help it with a gas burner to ignite it. This smells BAD and give off some toxic fumes. If you have a ventilator over the hob you should turn this on on full effect, disable any fire alarm (Remember to enable afterwards!) and be 100% sure that there isn't lots of fat in the ventilator that can ignite. It it is, put some aluminum foil over the flame.
    3: Mechanical: If it's one of those old fashion steel ones, you could take a knife and just start scraping it off. Cooling down the hob could help here, as it will make the plastic more brittle (Cooling spray works well, but is pretty expensive). A wire brush bit on a Dremel will also do the job, but you should do the entire top to keep it looking good.
    If the hob is a ceramic glass- thing you could get a razor and scrape it off. (The same kind they use to scrape paint of windows. They also make similar ones for scraping hobs. It's basically the same tool)
    If it's a gas hob you are screwed...
    Cooking top/plate. The hot circular thingys you put frying pans on to heat it.
  18. Nexxo
    23 Oct 2001
  19. Zurechial
    Zurechial Elitist
    21 Mar 2007
    This.
    Then garnish your food with AS5.
    Oh.. No, wait..
  20. D-Cyph3r
    D-Cyph3r Gay for Yunosuke
    31 Aug 2008
    *resists "overCOOKing" pun*
